We use an optical Probe for DO measurements. The measurements are temperature depended. Sofar the temperature was hard coded. However, I would like to read the temperature before the pO2 Measurement.
Unfortunately, I am not able to access the temperature if the thermostat is already running.
(e.g. instantiate “Thermocontroller” and call “read_external_temperature” method)
Is there a way to access the temperature directly Or do I need to modify the Thermononctoller to publish the temperature reading via mqtt?
Access temperature readings.
We use an optical probe for DO measurements. The measurements are temperature dependent. So far the temperature has been hard coded. However, I would like to read the temperature before the pO2 measurement.
Unfortunately I cannot access the temperature if the thermostat is already running.
(e.g. instantiate “thermocontroller” and call “read_external_temperature” method).
Is there a way to access the temperature directly or do I need to modify the thermocontroller to publish the temperature reading via mqtt?
Kind regards
Johannes
