As the software becomes more stable, we’ll be slowing down releases to closer to monthly cycles. Important bug fixes will always be prioritized however.
23.4.28
- improved detection of under-voltage, and power supply problems.
- pumps will halt if a MQTT disconnect occurs. This is to prevent the edge case when pumps are running on a worker, but not controllable from the UI due to an MQTT disconnect.
- improvements to backing up the SQLite3 database.
- improvements to self-test “Reference photodiode is correct magnitude”
- fix bug in
pio run od_calibration list
Problems? Let me know here or at cam@pioreactor.com
