There was a bug in 23.3.1, and a hotfix patch was released.
23.3.2
- fix bug in ending experiments not cleaning up automations properly.
23.3.1
This software and image are required for the Pioreactors sent out in February 2023.
- Removed Local Access Point from image - will return later, but need more time to investigate.
- Performance improvements
- Python dependencies for Pioreactor UI are now handled by this project.
- Better initialization of jobs from UI
- Version information now presented in UI
More Linux permission updates.
More support for HAT version 1.1
Refactor internal pumping code. There’s more flexibility that allows for solving parts of #384. Including:
- creating cleaning scripts
- creating cycling scripts, that also respect the rates of specific pumps vs waste (so that you don’t overflow if addition rate > removal rate)
Namely, new functions circulate_media
and circulate_alt_media
are introduced that will cycle both a pump and the waste pump simultaneously. The waste pump starts first and ends second.
Exposing the above routines in the UI, and improvements to the dosing UI:
- fixed
pio kill <job>
to actually kill a job
- Fix for running PID morbidostat
Changelog
Problems? Let me know here or at cam@pioreactor.com
Just tried updating from build 23.2.8.dev
I got this error, not sure if it is important:
19:32:46 |
pioreactor1 |
od reading |
Ready. |
19:32:43 |
pioreactor1 |
update-ui |
+ set -e + export LC_ALL=C + LC_ALL=C + SOURCE=/tmp/pioreactorui.tar.gz + TAG=23.3.1 + UI_FOLDER=/var/www/pioreactorui + tar -xvzf /tmp/pioreactorui.tar.gz -C /tmp + rsync -ap --ignore-existing /var/www/pioreactorui/contrib/ /tmp/pioreactorui-23.3.1/contrib/ + cp -p /var/www/pioreactorui/huey.db /tmp/pioreactorui-23.3.1 + cp -p /var/www/pioreactorui/huey.db-shm /tmp/pioreactorui-23.3.1 + cp -p /var/www/pioreactorui/huey.db-wal /tmp/pioreactorui-23.3.1 + cp -p /var/www/pioreactorui/.env /tmp/pioreactorui-23.3.1 + sudo rm -rf /var/www/pioreactorui + mkdir /var/www/pioreactorui + cp -rp /tmp/pioreactorui-23.3.1/. /var/www/pioreactorui + sudo chgrp -R www-data /var/www/pioreactorui + sudo pip install -r /var/www/pioreactorui/requirements.txt The folder you are executing pip from can no longer be found. |
19:32:33 |
pioreactor1 |
stirring |
Ready. |
19:32:30 |
pioreactor1 |
update-app |
Updated Pioreactor to version 23.3.1. |
19:32:10 |
pioreactor1 |
update-app |
Mmm right. That’s the result from an older build. Easiest solution:
sudo nano /usr/local/bin/update_ui.sh
And delete the line that looks like pip3 install -r ...
While your on the command line, I suggest running pio update ui
again to confirm it works.
