# Optical density not being recorded, although it is "Started"
**URL:** <https://forum.pioreactor.com/t/optical-density-not-being-recorded-although-it-is-started/248>\
**Category:** User interface\
**Created:** [March 6, 2024, 3:40pm UTC](https://forum.pioreactor.com/t/optical-density-not-being-recorded-although-it-is-started/248 "2024-03-06T15:40:50Z")\
**Posts on this page:** 1\
**Showing post:** 10
<div class="post-metadata">
**Author:** ![CamDavidsonPilon](https://forum.pioreactor.com/user_avatar/forum.pioreactor.com/camdavidsonpilon/32/3_2.png) [@CamDavidsonPilon](https://forum.pioreactor.com/u/CamDavidsonPilon)\
**Post date:** [June 10, 2024, 12:15pm UTC](https://forum.pioreactor.com/t/optical-density-not-being-recorded-although-it-is-started/248/10 "2024-06-10T12:15:41Z")
</div>
Leader-only images have this bug currently (fixed in the next release): you’ll have to use the manual fix here: [Leader only image bug - HardwarePWM not found - #3 by CamDavidsonPilon](https://forum.pioreactor.com/t/leader-only-image-bug-hardwarepwm-not-found/316/3)
I suspect the next release will come early this week with the fix (and other [changes](https://github.com/Pioreactor/pioreactor/blob/develop/CHANGELOG.md#upcoming))
```auto
pio update firmware
I don’t expect this to work, since the firmware lives on the HAT (plus you need the internet to pull) - what you probably are interested in is `pio update app` or `pio update ui`. _However_, if you want to the latest development versions, you can use `pio update app -b develop` and pio update ui -b develop` (both these require internet connection).
_[View the full topic](https://forum.pioreactor.com/t/optical-density-not-being-recorded-although-it-is-started/248)._
