Hey there,
Running experiments with RPM outside OD measurement right now leads to a little issue. When I set my original target RPM e.g. 1100 and start my experiment then after the first OD measurement this will also revert to the rpm_outside_od configuration e.g. 800 inside the config file or what I set under advanced settings. I think this is a little misleading and people might miss this then wondering why their whole experiment was running at 800 rpm. Starting their experiment and then wondering why it changed to a different RPM.
This is also connected to a little visual “bug” as the target RPM is not displayed in my UI after starting stirring but only when it was changed to the rpm_outside_od measurement. I would like if the default was that when I set a target RPM that the rpm_outside_od will also match that or there is a true/false or 0/1 setting that I can apply to have that.
sending greetings!
