Update failed, leader and workers on different versions
Hey,
of course, and thank you.
2024-10-24T16:03:31+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/create_diskcache.sh https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/create_diskcache.sh
2024-10-24T16:03:33+0200 [update_app] DEBUG
2024-10-24T16:03:33+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/huey.service https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/huey.service
2024-10-24T16:03:34+0200 [update_app] DEBUG
2024-10-24T16:03:34+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/lighttpd.conf https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/lighttpd.conf
2024-10-24T16:03:35+0200 [update_app] DEBUG
2024-10-24T16:03:35+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/lighttpd.service https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/lighttpd.service
2024-10-24T16:03:36+0200 [update_app] DEBUG
2024-10-24T16:03:36+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/lighttpd_packages.zip https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/lighttpd_packages.zip
2024-10-24T16:03:59+0200 [update_app] DEBUG
2024-10-24T16:03:59+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/pioreactorui_24.9.20.tar.gz https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/pioreactorui_24.9.20.tar.gz
2024-10-24T16:04:02+0200 [update_app] DEBUG
2024-10-24T16:04:02+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/release_24.9.19.zip https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/release_24.9.19.zip
2024-10-24T16:04:33+0200 [update_app] DEBUG
2024-10-24T16:04:33+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/release_24.9.19.zip.sha256 https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/release_24.9.19.zip.sha256
2024-10-24T16:04:34+0200 [update_app] DEBUG
2024-10-24T16:04:34+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/update_ui.sh https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/update_ui.sh
2024-10-24T16:04:35+0200 [update_app] DEBUG
2024-10-24T16:04:35+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/wheels_24.9.19.zip https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/wheels_24.9.19.zip
2024-10-24T16:04:37+0200 [update_app] DEBUG
2024-10-24T16:04:37+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/pre_update.sh https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/pre_update.sh
2024-10-24T16:04:39+0200 [update_app] DEBUG
2024-10-24T16:04:39+0200 [update_app] DEBUG sudo bash /tmp/release_24.9.19/pre_update.sh
2024-10-24T16:04:40+0200 [update_app] DEBUG Version check passed: 24.8.22
2024-10-24T16:04:40+0200 [update_app] DEBUG sudo pip3 install “pioreactor @ https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/pioreactor-24.9.19-py3-none-any.whl
2024-10-24T16:04:43+0200 [update_app] DEBUG error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
For more information visit http://rptl.io/venv
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
2024-10-24T16:04:43+0200 [update_app] ERROR Update failed. See logs.
2024-10-24T16:05:18+0200 [update_app] DEBUG rm -rf /tmp/release_24.9.19
2024-10-24T16:05:18+0200 [update_app] DEBUG mkdir /tmp/release_24.9.19
2024-10-24T16:05:18+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/50-pioreactorui.conf https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/50-pioreactorui.conf
2024-10-24T16:05:19+0200 [update_app] DEBUG
2024-10-24T16:05:19+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/52-api-only.conf https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/52-api-only.conf
2024-10-24T16:05:20+0200 [update_app] DEBUG
2024-10-24T16:05:20+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/CHANGELOG.md https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/CHANGELOG.md
2024-10-24T16:05:22+0200 [update_app] DEBUG
2024-10-24T16:05:22+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/create_diskcache.service https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/create_diskcache.service
2024-10-24T16:05:23+0200 [update_app] DEBUG
2024-10-24T16:05:23+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/create_diskcache.sh https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/create_diskcache.sh
2024-10-24T16:05:25+0200 [update_app] DEBUG
2024-10-24T16:05:25+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/huey.service https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/huey.service
2024-10-24T16:05:25+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/lighttpd.conf https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/lighttpd.conf
2024-10-24T16:05:26+0200 [update_app] DEBUG
2024-10-24T16:05:26+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/lighttpd.service https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/lighttpd.service
2024-10-24T16:05:27+0200 [update_app] DEBUG
2024-10-24T16:05:27+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/lighttpd_packages.zip https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/lighttpd_packages.zip
2024-10-24T16:05:51+0200 [update_app] DEBUG
2024-10-24T16:05:51+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/pioreactorui_24.9.20.tar.gz https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/pioreactorui_24.9.20.tar.gz
2024-10-24T16:05:54+0200 [update_app] DEBUG
2024-10-24T16:05:54+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/release_24.9.19.zip https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/release_24.9.19.zip
2024-10-24T16:06:21+0200 [update_app] DEBUG
2024-10-24T16:06:21+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/release_24.9.19.zip.sha256 https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/release_24.9.19.zip.sha256
2024-10-24T16:06:21+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/update_ui.sh https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/update_ui.sh
2024-10-24T16:06:22+0200 [update_app] DEBUG
2024-10-24T16:06:22+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/wheels_24.9.19.zip https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/wheels_24.9.19.zip
2024-10-24T16:06:24+0200 [update_app] DEBUG
2024-10-24T16:06:24+0200 [update_app] DEBUG wget -O /tmp/release_24.9.19/pre_update.sh https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/pre_update.sh
2024-10-24T16:06:25+0200 [update_app] DEBUG
2024-10-24T16:06:25+0200 [update_app] DEBUG sudo bash /tmp/release_24.9.19/pre_update.sh
2024-10-24T16:06:26+0200 [update_app] DEBUG Version check passed: 24.8.22
2024-10-24T16:06:26+0200 [update_app] DEBUG sudo pip3 install “pioreactor @ https://github.com/Pioreactor/pioreactor/releases/download/24.9.19/pioreactor-24.9.19-py3-none-any.whl
2024-10-24T16:06:29+0200 [update_app] DEBUG error: externally-managed-environment
install.
2024-10-24T16:06:29+0200 [update_app] ERROR Update failed. See logs.
tail: cannot open ‘’ for reading: No such file or directory
