We put all our available 3D printing files and designs on Printables.
We recently add a blank vial cap you can use to start designing your own caps: blank vial cap
Added the complete set of printable parts for the Pioreactor 20ml: Printables
Also added our heater PCB: hardware/heater_20ml/Heater_Jan_0824_Public at master · Pioreactor/hardware · GitHub
I thought it would be a fun project to try and build the heater PCB by hand, but I ran into some problems. Even without a BOM, I was able to procure most of the components by looking at the schematic, apart from the two metal spacers. I tried to measure them (3mm height, 4.8mm diameter, M2.5 thread?) but I’m not sure where to buy them?
As the gerbers are available it was easy to make the PCB, but as there’s no CPL file (Component Placement List), and the silkscreen does not have the component references either, I’m not entirely sure where each component should be placed. I guess I could try to reverse-engineer it from the gerbers and the schematic, but thought I’d ask first! ![]()
I was wondering whether you had considered publishing the source files? That would make it easier to contribute improvements to the designs, whereas with just a PDF of the schematic and the gerbers we would mostly just be able to manufacture the design.
I was also not sure what the intended open-source license is, as the schematic PDF only says “OPEN SOURCE - FREE TO DISTRIBUTE” and I couldn’t find any license files in the repo.
Ah good points, thanks @gendor for asking about this. We clearly need to fill in these details (especially the missing license!) Let me talk to the team and report back early next week.
Hi Cam!
Any feedback on the heater PCB:
Also, I’ve been wondering if you’ve been able to make progress towards open sourcing the HAT PCB?
One last thing: Would you be willing to open source your GL45 cap design? I looked on your Printables profile but couldn’t find it.
Hi @gendor,
Some updates: We’re still developing our open-source strategy. To be transparent: we are (likely) moving our PCB development from Altium to KiCAD, and we’ll feel more confident open sourcing designs from KiCAD.
That’s great news, thanks Cam! My two cents: I’ve worked with both KiCAD and Altium, and KiCAD is my preferred tool for electronics development.
I’ve been using it for a new board design, and have found it comparable or better to Fusion 360’s electronic tool (I don’t use Altium, only my partner).
Okay some updates:
Hello Cam,
The GL45 Screw Cap design is still not available on Printables i think.
Hi Cameron,
Could you please share the design of vial cap B which has four barbed connectors?
Thank you,
Sansanee
Yup, added now: Vial Cap B for the Pioreactor by Pioreactor | Download free STL model | Printables.com
GL45 caps are coming soon™️
Hi Cam and Pioreactor team,
Could the dovetail platform for B/B+ RPis be shared? Thank you!
Hi @DonalC, its available too: Pioreactor platform with dovetails for B models by Pioreactor | Download free STL model | Printables.com
Hi Cam, I missed it looking at just the highlighted section, thanks for linking it!
A somewhat relevant q: do you have any dimensions for the 20 mL vials on hand? In particular, the diameter and height (with or without cap is fine - but would help if clarified which)
