Air Bubbler not starting after 25.5.22 update
Hi
I updated the pioreactor to 25.5.22 and updated the Raspberry Pi OS to 25-5-13 and I can’t get the Air Bubbler to start anymore. Originally I updated the pioreactor using the ‘Update’ feature in the UI and updated the Raspberry Pi OS with ‘sudo apt update’ followed by ‘sudo apt full-upgrade’. Then I tried downloading the latest image and burning the SD card again. Both ways seem to give the same issue when the Air Bubbler is asked to start. I think it’s the ‘pubsub_client’ argument on line 33 that’s giving me my issue but now i’ve ran out of talent. Is anyone able to help me out on this one? Thanks!
$ pio run air_bubbler
2025-05-25T16:09:07+0100 DEBUG [air_bubbler] Init.
2025-05-25T16:09:07+0100 DEBUG [air_bubbler] Error in on_disconnected:
2025-05-25T16:09:07+0100 DEBUG [air_bubbler] ‘AirBubbler’ object has no attribute ‘pwm’
File “/usr/local/lib/python3.11/dist-packages/pioreactor/background_jobs/base.py”, line 262, in wrapped_init
orig_init(self, *args, **kwargs)
File “/usr/local/lib/python3.11/dist-packages/pioreactor_air_bubbler/init.py”, line 33, in init
self.pwm = PWM(
TypeError: PWM.init() got an unexpected keyword argument ‘pubsub_client’
During handling of the above exception, another exception occurred:
File “/usr/local/lib/python3.11/dist-packages/pioreactor/background_jobs/base.py”, line 784, in disconnected
self.on_disconnected()
File “/usr/local/lib/python3.11/dist-packages/pioreactor_air_bubbler/init.py”, line 40, in on_disconnected
self.pwm.stop()
AttributeError: ‘AirBubbler’ object has no attribute ‘pwm’
2025-05-25T16:09:07+0100 INFO [air_bubbler] Disconnected.
2025-05-25T16:09:07+0100 DEBUG [air_bubbler] Disconnected successfully from MQTT.
File “/usr/local/bin/pio”, line 8, in
sys.exit(pio())
File “/usr/local/lib/python3.11/dist-packages/pioreactor_air_bubbler/init.py”, line 83, in start_air_bubbler
ab = AirBubbler(unit=unit, experiment=experiment, duty_cycle=dc, hertz=hertz)
File “/usr/local/lib/python3.11/dist-packages/pioreactor/background_jobs/base.py”, line 109, in call
obj = type.call(cls, *args, **kwargs)
self.pwm = PWM(
Hi @stebol,
Shoot, you’re right, the update did break this plugin (and also the relay-plugin). I’ll fix first thing tomorrow!
Hi @stebol,
There’s a new pioreactor-air-bubbler version 0.9.0 available with a fix in it.
(and a new pioreactor-relay version 0.7.0 out too)
