Assertion Error in dosing automation for self._latest_od
Hey, its me again
I’ve updated to version 25.03.05 and have a new error when playing with dosing automations.
This is my minimal not working example, the od_reading job has been started through the UI before executing this through the worker command line:
class MNWE(DosingAutomationJobContrib):
    automation_name = "MNWE"
    def __init__(self, **kwargs):
        super(MNWE,self).__init__(**kwargs)
        self.logger.debug(f"Latest OD: {self.latest_od}")
And that is the console output:
pioreactor@Auto-P01:~ $ pio run dosing_automation --automation-name MNWE
2025-03-06T15:01:53+0100 DEBUG  [dosing_automation] Init.
2025-03-06T15:01:53+0100 INFO   [dosing_automation] Starting MNWE.
2025-03-06T15:01:53+0100 WARNING [dosing_automation] It's recommended to have stirring on to improve mixing during dosing events.
2025-03-06T15:01:53+0100 DEBUG  [dosing_automation] Waiting for OD and growth rate data to arrive
2025-03-06T15:01:53+0100 ERROR  [dosing_automation]
  File "/usr/local/lib/python3.11/dist-packages/pioreactor/background_jobs/dosing_automation.py", line 724, in start_dosing_automation
    return klass(
  File "/usr/local/lib/python3.11/dist-packages/pioreactor/background_jobs/base.py", line 105, in __call__
    obj = type.__call__(cls, *args, **kwargs)
  File "/home/pioreactor/.pioreactor/plugins/MNWE.py", line 10, in __init__
  File "/usr/local/lib/python3.11/dist-packages/pioreactor/background_jobs/dosing_automation.py", line 544, in latest_od
    assert self._latest_od is not None
AssertionError
    sys.exit(pio())
  File "/usr/local/lib/python3.11/dist-packages/click/decorators.py", line 33, in new_func
    return f(get_current_context(), *args, **kwargs)
  File "/usr/local/lib/python3.11/dist-packages/pioreactor/background_jobs/dosing_automation.py", line 765, in click_dosing_automation
    la = start_dosing_automation(
  File "/usr/local/lib/python3.11/dist-packages/pioreactor/background_jobs/dosing_automation.py", line 737, in start_dosing_automation
    raise e
    return klass(
AssertionError
2025-03-06T15:01:53+0100 DEBUG  [dosing_automation] Exiting caused by Python atexit.
2025-03-06T15:01:53+0100 INFO   [dosing_automation] Disconnected.
2025-03-06T15:01:54+0100 DEBUG  [dosing_automation] Disconnected successfully from MQTT.
Thanks and best,
Kai
P.S.: I am unsure if software bugs should be posted here on the forum or if it would be better to move them to github?
So this isn’t a bug, but a gotcha. You can access self.latest_od only after it’s populated and has data available. This data comes from MQTT, and might take a few seconds to populate. Can you try adding a time.sleep(5) before the debug statement?
Looking at the code, there is an improvement I can make here to make it more clear what’s going on, so it’s kinda a bug, yes.
I think here initially, and we can triage to GH!
Ahh I see. Then I will keep this here on the forum :smiley:
Sadly the addition of the sleep did not resolve it. I am running the OD measurement with an interval of 10 seconds and can see on the UI graph that it is running and producing datapoints. The code of the MNWE is now the following:
from pioreactor.utils.timing import current_utc_timestamp
import time
        self.logger.debug(f"Current timestamp: {current_utc_timestamp()}")
        time.sleep(20)
and the output is this:
2025-03-06T17:06:17+0100 DEBUG  [dosing_automation] Init.
2025-03-06T17:06:17+0100 INFO   [dosing_automation] Starting MNWE.
2025-03-06T17:06:18+0100 WARNING [dosing_automation] It's recommended to have stirring on to improve mixing during dosing events.
2025-03-06T17:06:18+0100 DEBUG  [dosing_automation] Current timestamp: 2025-03-06T16:06:18.005Z
2025-03-06T17:06:38+0100 DEBUG  [dosing_automation] Current timestamp: 2025-03-06T16:06:38.008Z
2025-03-06T17:06:38+0100 DEBUG  [dosing_automation] Waiting for OD and growth rate data to arrive
2025-03-06T17:06:38+0100 ERROR  [dosing_automation]
    return klass(
  File "/home/pioreactor/.pioreactor/plugins/MNWE.py", line 13, in __init__
AssertionError
    sys.exit(pio())
    raise e
    return klass(
AssertionError
2025-03-06T17:06:38+0100 DEBUG  [dosing_automation] Exiting caused by Python atexit.
2025-03-06T17:06:43+0100 DEBUG  [dosing_automation] run_thread still alive!
2025-03-06T17:06:43+0100 INFO   [dosing_automation] Disconnected.
2025-03-06T17:06:44+0100 DEBUG  [dosing_automation] Disconnected successfully from MQTT.
As always thanks for your help :slight_smile:
I can reproduce locally - let me see why this is happening and get a solution for you.
Okay, so the solution is simple, but not obvious. The flow that populates these latest_* attributes starts in self.start_passive_listeners() (see here), but that code only runs after the __init__ is finished (see here).
Anyways, the solution for you is to just start that sooner:
import time
Yep that solves it. Thank you so much!
Best, Kai
