Bidirectional pumping
Hello! We would like to use the pumps to automatically inoculate the pioreactors. We cannot use the media pumps for this, because the media tubes would get contaminated with bacteria. Instead we would like to use the waste tubing to transfer the inoculum. Therefore, we would like to change the direction of the waste pumps for the inoculation process. We would like this change of direction to be controlled by software (rather than switching the wires around for the media and waste pumps) as we are running a cluster (24 workers) large enough that the manual switching feels fidely and error prone.
My understanding is that changing the direction of the polarity isn’t possible through the dosing automation or through the relay plugin (which turns whatever is connected to the GPIO pin on and off) and we would need some new hardware which changes the polarity (something like this h-bridge motor driver), and then I’d need to write a background job which controls the Raspberry Pi’s GPIO pins. I think I can build on the SoftwarePWMOutputDevice so that it can control multiple pins to allow me to make the pumping bidirectional. I might need to do something similar to the dosing automation’s safety catches to prevent too overflow of liquid.
Has anyone done something like this before? Any collective wisdom gratefully received. :slight_smile:
That’s a nice idea. We’re working on a remote control pioreactor that we’d like to be able to use with schools. We were contemplating using a syringe for inoculation (mainly for visual impact), but your dual-purpose waste pump could simplify things.
The ‘Maker Drive’ that you linked to boasts ‘Reverse Polarity Protection’. I’m no expert, but I’m wondering if it deliberately avoids reversing the motor. I was also thinking that a stackable HAT solution might be nice. Possibly this Adafruit DC & Stepper Motor HAT for Raspberry Pi - Mini Kit (also available from the Pi Hut). I think you’d also need a stacking header (Adafruit/Pi Hut) and standoffs (Adafruit/Pi Hut).
Hi Martin, thanks very much for getting back to me. I like the idea of multi-storey HATs! I will update here once I make some progress on this. All the best, Vicky
Hi! I was wondering if you made any progress on this matter? i am looking at similar things :slight_smile:
Hi Leo, we have ordered these but not tested them yet. Lmk how you get on! Thanks, Vicky
As part of the experiments we are performing we need to purge the input (media) line of our media between dosings (6hrs) so the line doesn’t clog. We have a setup that will be able to purge the line (with RO water) in place if we can run the media pump in reverse.
Is there a way for us to run the pumps in revers as part of our profile code?
(I tried using negative pumping volumes in the profile but got no response or even error during execution)
Hi @Karm.RFA, there isn’t a out-of-the-box way to reverse the pump direction, however, this will be possible in a future hardware update.
@Karm.RFA - I didn’t do anything on this in the end. If I do before the hardware update, I will post something.
