Hey @CamDavidsonPilon , it seems like you have an interest in math and statistics and I thought you might find this question interesting to think about.
How would you “quantify” the distance between two dosing functions over a period of time into a number? For example, imagine I’m running an experiment with 1 through N pioreactors, and pioreactor ‘x’ (P_x) is a chemostat operating at these values at time ‘t’:
- Media (dose/hour): a_dose(x, t) = A_x * sin( W_x * t) + B_x
- Alternate Media (dose/hour): am_dose(x, t) = C_x * sin( Y_x * t) + D_x
- Target Temperature (temp_setpoint): temp(x, t) = E_x * sin( Z_x * t) + F_x
A_x is an element from [A_min, A_max]
B_x, C_x, etc… elements from [B/C_min, B/C_max]
I was thinking to try and use a distance formula to try and find the distance between P_x1 and P_x2.
Distance(P_x1, P_x2) = sqrt( [a_dose(x2, t) - a_dose(x1, t)]^2 + [ am_dose(x2, t) - am_dose(x1, t)]^2 + …
If I run all of the settings using a sine/cosine function, then I want a normalized general function that can give me the “distance” between two sine/cosine functions at time “t”. This could look like
norm_dist_a (x1, x2, t) = [ a_dose(x2, t) - a_dose(x1, t) ] ^ 2 / [ a_dose_max - a_dose_min ] ^ 2
norm_dist_am (x1, x2, t) = [ am_dose(x2, t) - am_dose(x1, t) ] ^ 2 / [ am_dose_max - am_dose_min ] ^ 2
norm_dist_temp (x1, x2, t) = [ temp(x2, t) - temp(x1, t) ] ^ 2 / [ temp_max - temp_min ] ^ 2
Then, the distance between P_x1 and P_x2 at time t is:
Distance(P_x1, P_x2, t) = sqrt( norm_dist_a(x1, x2, t) + norm_distance_am(x1, x2, t) + norm_distance_temp(x1, x2, t) )
Using this, you can calculate a distance between two pioreactor environments at time t, but is there a way to extend this concept of a “distance” over a period of time, 24 hours for example. I’m not too familiar with statistics, but this seems like an applicable approach to see and quantify the distribution of distances between X1 and X2 over a 24 hour period.
What are your thoughts?
