Command line software app update failure
While trying to update the software, I accidentally used one of the development versions. After this, I tried to update the software back to the latest version, however I ended up with the following error in the command line interface of the leader pioreactor:
2024-09-02T13:25:19+0200 DEBUG  [update_app] rm -rf /tmp/release_24.8.22
2024-09-02T13:25:19+0200 DEBUG  [update_app] mkdir /tmp/release_24.8.22
2024-09-02T13:25:19+0200 DEBUG  [update_app] wget -O /tmp/release_24.8.22/CHANGELOG.md https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/CHANGELOG.md
2024-09-02T13:25:20+0200 DEBUG  [update_app]
2024-09-02T13:25:20+0200 DEBUG  [update_app] wget -O /tmp/release_24.8.22/main.elf https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/main.elf
2024-09-02T13:25:21+0200 DEBUG  [update_app]
2024-09-02T13:25:21+0200 DEBUG  [update_app] wget -O /tmp/release_24.8.22/pioreactorui_24.8.21.tar.gz https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pioreactorui_24.8.21.tar.gz
2024-09-02T13:25:23+0200 DEBUG  [update_app]
2024-09-02T13:25:23+0200 DEBUG  [update_app] wget -O /tmp/release_24.8.22/release_24.8.22.zip https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/release_24.8.22.zip
2024-09-02T13:25:26+0200 DEBUG  [update_app]
2024-09-02T13:25:26+0200 DEBUG  [update_app] wget -O /tmp/release_24.8.22/release_24.8.22.zip.sha256 https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/release_24.8.22.zip.sha256
2024-09-02T13:25:27+0200 DEBUG  [update_app]
2024-09-02T13:25:27+0200 DEBUG  [update_app] wget -O /tmp/release_24.8.22/wheels_24.8.22.zip https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/wheels_24.8.22.zip
2024-09-02T13:25:29+0200 DEBUG  [update_app]
2024-09-02T13:25:29+0200 DEBUG  [update_app] wget -O /tmp/release_24.8.22/pre_update.sh https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pre_update.sh
2024-09-02T13:25:30+0200 DEBUG  [update_app]
2024-09-02T13:25:30+0200 DEBUG  [update_app] sudo bash /tmp/release_24.8.22/pre_update.sh
2024-09-02T13:25:31+0200 DEBUG  [update_app] Version check passed: 24.8.22
2024-09-02T13:25:31+0200 DEBUG  [update_app] sudo pip3 install "pioreactor @ https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pioreactor-24.8.22-py3-none-any.whl"
2024-09-02T13:25:39+0200 DEBUG  [update_app] Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting pioreactor@ https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pioreactor-24.8.22-py3-none-any.whl
  Downloading https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pioreactor-24.8.22-py3-none-any.whl (232 kB)
     ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ 232.7/232.7 kB 1.3 MB/s eta 0:00:00
Requirement already satisfied: click==8.1.7 in /usr/local/lib/python3.11/dist-packages (from pioreactor@ https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pioreactor-24.8.22-py3-none-any.whl) (8.1.7)
Requirement already satisfied: paho-mqtt==2.1.0 in /usr/local/lib/python3.11/dist-packages (from pioreactor@ https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pioreactor-24.8.22-py3-none-any.whl) (2.1.0)
Requirement already satisfied: sh==2.0.6 in /usr/local/lib/python3.11/dist-packages (from pioreactor@ https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pioreactor-24.8.22-py3-none-any.whl) (2.0.6)
Requirement already satisfied: JSON-log-formatter==0.5.1 in /usr/local/lib/python3.11/dist-packages (from pioreactor@ https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pioreactor-24.8.22-py3-none-any.whl) (0.5.1)
Requirement already satisfied: colorlog==6.7.0 in /usr/local/lib/python3.11/dist-packages (from pioreactor@ https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pioreactor-24.8.22-py3-none-any.whl) (6.7.0)
Requirement already satisfied: msgspec==0.18.5 in /usr/local/lib/python3.11/dist-packages (from pioreactor@ https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pioreactor-24.8.22-py3-none-any.whl) (0.18.5)
Requirement already satisfied: diskcache==5.6.3 in /usr/local/lib/python3.11/dist-packages (from pioreactor@ https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pioreactor-24.8.22-py3-none-any.whl) (5.6.3)
Requirement already satisfied: crudini==0.9.5 in /usr/local/lib/python3.11/dist-packages (from pioreactor@ https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pioreactor-24.8.22-py3-none-any.whl) (0.9.5)
Requirement already satisfied: iniparse==0.5 in /usr/local/lib/python3.11/dist-packages (from pioreactor@ https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pioreactor-24.8.22-py3-none-any.whl) (0.5)
Requirement already satisfied: six==1.16.0 in /usr/local/lib/python3.11/dist-packages (from pioreactor@ https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pioreactor-24.8.22-py3-none-any.whl) (1.16.0)
2024-09-02T13:25:39+0200 DEBUG  [update_app] wget -O /tmp/release_24.8.22/update.sh https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/update.sh
2024-09-02T13:25:40+0200 DEBUG  [update_app]
2024-09-02T13:25:40+0200 DEBUG  [update_app] sudo bash /tmp/release_24.8.22/update.sh
2024-09-02T13:25:44+0200 DEBUG  [update_app] + export LC_ALL=C
+ LC_ALL=C
+ PIO_DIR=/home/pioreactor/.pioreactor
+++ dirname /tmp/release_24.8.22/update.sh
++ cd /tmp/release_24.8.22
++ pwd
+ SCRIPT_DIR=/tmp/release_24.8.22
++ hostname
+ HOSTNAME=L02
++ crudini --get /home/pioreactor/.pioreactor/config.ini cluster.topology leader_hostname
+ LEADER_HOSTNAME=L02
+ '[' L02 = L02 ']'
+ touch /home/pioreactor/.pioreactor/config_L02.ini
+ crudini --ini-options=nospace --set /home/pioreactor/.pioreactor/config_L02.ini cluster.topology leader_address 127.0.0.1
+ crudini --ini-options=nospace --set /home/pioreactor/.pioreactor/config_L02.ini mqtt broker_address 127.0.0.1
+ for ini_file in "$PIO_DIR"/config*.ini
+ echo 'Processing file: /home/pioreactor/.pioreactor/config.ini'
+ crudini --get /home/pioreactor/.pioreactor/config.ini stirring
+ echo 'No [stirring] section found in /home/pioreactor/.pioreactor/config.ini. Skipping.'
+ echo 'Processing file: /home/pioreactor/.pioreactor/config_L02.ini'
+ crudini --get /home/pioreactor/.pioreactor/config_L02.ini stirring
+ echo 'No [stirring] section found in /home/pioreactor/.pioreactor/config_L02.ini. Skipping.'
+ crudini --get /home/pioreactor/.pioreactor/config.ini od_config
+ echo 'No [od_config] section found in /home/pioreactor/.pioreactor/config.ini. Skipping.'
+ crudini --get /home/pioreactor/.pioreactor/config_L02.ini od_config
+ echo 'No [od_config] section found in /home/pioreactor/.pioreactor/config_L02.ini. Skipping.'
+ sudo -u pioreactor pios sync-configs
  File "/usr/local/bin/pios", line 8, in <module>
    sys.exit(pios())
  File "/usr/local/lib/python3.11/dist-packages/pioreactor/cli/pios.py", line 425, in sync_configs
    units = add_leader(universal_identifier_to_all_workers(units))
  File "/usr/local/lib/python3.11/dist-packages/pioreactor/cli/pios.py", line 61, in universal_identifier_to_all_workers
    units = get_workers_in_inventory()
  File "/usr/local/lib/python3.11/dist-packages/pioreactor/cluster_management/__init__.py", line 29, in get_workers_in_inventory
    return tuple(worker["pioreactor_unit"] for worker in result.json())
  File "/usr/local/lib/python3.11/dist-packages/pioreactor/mureq.py", line 234, in json
    return loads(self.body)
msgspec.DecodeError: JSON is malformed: invalid character (byte 0)
2024-09-02T13:25:44+0200 ERROR  [update_app] Update failed. See logs.
Additional information:
  • I can run all the leader commands except for commands regarding software update and worker pioeractors (e.g., pio/pios update, pio workers, pios sync-configs, etc.)
  • I cannot update the software from the zip file either for some reason.
Does anyone know what could be the potential problem and how to fix it?
Hm, try this on your leader
pio update ui
This will revert what I think is the problem: an error in the web backend on the development branch. You can check this by running pio version -v to check that the pioreactor-ui version is something like 24.8.21.
and then try:
pios update
This will turn all your Pioreactors back to the most recent version (24.8.21).
Thanks for the suggestion but I already tried that and I can update the ui but that does not fix the problem to update the leader.
Also, when I open the UI the website also seems to be down because I cannot see anything in the inventory and I get html code errors in some of the sections
Can you try updating the leader in isolation? On the leader: pio update app - does that work? From there, can you run pio version -v to confirm the leader’s software is up to date.
Then try pios update?
I also tried that already both using the zip file and also by the pio update app in the command line interface. Both end up with the same error log I attached above.
I cannot check the leader command at the moment but I assume it is stuck in the development software version ad trying to update it to any version ends up with the same error log. I will check that and inform the version if I can see.
Also just to be clear we do not have problem with worked as I transferred those to another cluster and uodated to the latest version. The problem is more in the leader only pioreactor.
Ah, I think this is the clue. Sounds like the web server is offline. Can you try
sudo systemctl restart lighttpd.service
on the leader. If you produces an error, can you try
sudo systemctl status lighttpd.service
and report the output?
Once the UI is back working, I think the pio commands above will work again.
The webserver is online and accessible but it is in a crashed state I would say. This is the state:
lighttpd.service - Lighttpd Daemon
     Loaded: loaded (/lib/systemd/system/lighttpd.servi>
     Active: active (running) since Tue 2024-09-03 15:5>
    Process: 18441 ExecStartPre=/usr/sbin/lighttpd -tt >
   Main PID: 18447 (lighttpd)
      Tasks: 1 (limit: 383)
        CPU: 8.346s
     CGroup: /system.slice/lighttpd.service
             └─18447 /usr/sbin/lighttpd -D -f /etc/ligh>
Sep 03 15:59:53 L02 lighttpd[18465]:                   >
Sep 03 15:59:53 L02 lighttpd[18465]:   File "/usr/lib/p>
Sep 03 15:59:53 L02 lighttpd[18465]:     logging.FileHa>
Sep 03 15:59:53 L02 lighttpd[18465]:     StreamHandler.>
Sep 03 15:59:53 L02 lighttpd[18465]:     return open_fu>
Sep 03 15:59:53 L02 lighttpd[18465]:            ^^^^^^^>
Sep 03 15:59:53 L02 lighttpd[18465]: PermissionError: [>
...skipping...
ooo I think I know what happened. Yes I definitely know. Run the following on your leader:
sudo chmod 666 /var/log/pioreactor.log
sudo sed -i 's/create 0660 pioreactor pioreactor/create 0666 pioreactor pioreactor/' /etc/logrotate.d/pioreactor
Then your UI should work (i.e. no more html stuff). Then try the pio commands. I strongly suggest running pio update app and pio update ui on your leader (even if you already did), and then pios update.
I’ve also removed the “update to development” from the UI - it is too much of a foot gun.
After running the sudo commands, this is the output I get from running pio update app
2024-09-03T16:41:59+0200 DEBUG  [update_app] rm -rf /tmp/release_24.8.22
2024-09-03T16:41:59+0200 DEBUG  [update_app] mkdir /tmp/release_24.8.22
2024-09-03T16:41:59+0200 DEBUG  [update_app] wget -O /tmp/release_24.8.22/CHANGELOG.md https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/CHANGELOG.md
2024-09-03T16:42:01+0200 DEBUG  [update_app]
2024-09-03T16:42:01+0200 DEBUG  [update_app] wget -O /tmp/release_24.8.22/main.elf https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/main.elf
2024-09-03T16:42:02+0200 DEBUG  [update_app]
2024-09-03T16:42:02+0200 DEBUG  [update_app] wget -O /tmp/release_24.8.22/pioreactorui_24.8.21.tar.gz https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pioreactorui_24.8.21.tar.gz
2024-09-03T16:42:04+0200 DEBUG  [update_app]
2024-09-03T16:42:04+0200 DEBUG  [update_app] wget -O /tmp/release_24.8.22/release_24.8.22.zip https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/release_24.8.22.zip
2024-09-03T16:42:08+0200 DEBUG  [update_app]
2024-09-03T16:42:08+0200 DEBUG  [update_app] wget -O /tmp/release_24.8.22/release_24.8.22.zip.sha256 https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/release_24.8.22.zip.sha256
2024-09-03T16:42:10+0200 DEBUG  [update_app]
2024-09-03T16:42:10+0200 DEBUG  [update_app] wget -O /tmp/release_24.8.22/wheels_24.8.22.zip https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/wheels_24.8.22.zip
2024-09-03T16:42:12+0200 DEBUG  [update_app]
2024-09-03T16:42:12+0200 DEBUG  [update_app] wget -O /tmp/release_24.8.22/pre_update.sh https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pre_update.sh
2024-09-03T16:42:13+0200 DEBUG  [update_app]
2024-09-03T16:42:13+0200 DEBUG  [update_app] sudo bash /tmp/release_24.8.22/pre_update.sh
2024-09-03T16:42:14+0200 DEBUG  [update_app] Version check passed: 24.8.22
2024-09-03T16:42:14+0200 DEBUG  [update_app] sudo pip3 install "pioreactor @ https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/pioreactor-24.8.22-py3-none-any.whl"
2024-09-03T16:42:22+0200 DEBUG  [update_app] Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
     ━━━━━━━━━━━━━━━ 232.7/232.7 kB 1.4 MB/s eta 0:00:00
2024-09-03T16:42:22+0200 DEBUG  [update_app] wget -O /tmp/release_24.8.22/update.sh https://github.com/Pioreactor/pioreactor/releases/download/24.8.22/update.sh
2024-09-03T16:42:23+0200 DEBUG  [update_app]
2024-09-03T16:42:23+0200 DEBUG  [update_app] sudo bash /tmp/release_24.8.22/update.sh
2024-09-03T16:43:24+0200 DEBUG  [update_app] + export LC_ALL=C
+ LC_ALL=C
++ pwd
++ hostname
+ HOSTNAME=L02
+ '[' L02 = L02 ']'
2024-09-03T16:42:26+0200 DEBUG  [sync_configs] Syncing configs on P11...
2024-09-03T16:42:31+0200 DEBUG  [sync_configs] Syncing configs on P12...
2024-09-03T16:42:36+0200 WARNING [sync_configs] Encountered error syncing configs to P12.
2024-09-03T16:42:36+0200 DEBUG  [sync_configs]
  RAN: /usr/bin/rsync -z --timeout 30 --inplace -e ssh /home/pioreactor/.pioreactor/config.ini P12.local:/home/pioreactor/.pioreactor/config.ini
  STDOUT:
  STDERR:
ssh: Could not resolve hostname p12.local: Name or service not known
rsync: connection unexpectedly closed (0 bytes received so far) [sender]
rsync error: unexplained error (code 255) at io.c(231) [sender=3.2.7]
  File "/usr/local/lib/python3.11/dist-packages/pioreactor/cli/pios.py", line 433, in _thread_function
    sync_config_files(unit, shared, specific)
  File "/usr/local/lib/python3.11/dist-packages/pioreactor/cli/pios.py", line 113, in sync_config_files
    cp_file_across_cluster(unit, localpath, remotepath, timeout=30)
  File "/usr/local/lib/python3.11/dist-packages/pioreactor/utils/networking.py", line 17, in cp_file_across_cluster
    rsync(
  File "/usr/local/lib/python3.11/dist-packages/sh.py", line 1508, in __call__
    rc = self.__class__.RunningCommandCls(cmd, call_args, stdin, stdout, stderr)
  File "/usr/local/lib/python3.11/dist-packages/sh.py", line 737, in __init__
    self.wait()
  File "/usr/local/lib/python3.11/dist-packages/sh.py", line 799, in wait
    self.handle_command_exit_code(exit_code)
  File "/usr/local/lib/python3.11/dist-packages/sh.py", line 826, in handle_command_exit_code
    raise exc
sh.ErrorReturnCode_255:
  STDOUT:
  STDERR:
2024-09-03T16:43:22+0200 DEBUG  [sync_configs] Syncing configs on L02...
Aborted!
However, I transferred all the workers and removed the config files…but it seems the leader still tries to sync configs.
I think generally everything worked out, but it’s trying to sync configs to p12 (which is not available?), and failing here. This is the last step, so I wouldn’t worry about it failing.
Like you removed all the workers from the inventory? But it still thinks p12 is in the inventory?
I removed the workers through the CLI pio workers remove. However, even after removing their config files remained so I manually deleted them on the CLI.
Nevertheless, after running the sudo commands you recommended above, the workers were added back to the leader as running pio workers status illustrated all the workers remaining in the leader. Hence, I removed the workers again by the command pio workers remove --unit and manage to update the leader app and ui through the CLI.
