Dear friends!
I am using a Pio-cluster (being the leader a RBPI5).
I keep getting the warning message from monitor of:
“CPU temperature at 79 ℃”
Any idea of what this could be?
Thanks in advance!
Dear friends!
Thanks in advance!
That’s pretty warm for a Raspberry Pi, but also expected! RPi5s do consume a lot more power than other versions. A hot RPi (above 80C) will throttle itself, so you might be losing some performance. A few ways things you might consider changing:
Hi! I’ve had similar issues. I have now decreased the tª of the chamber where the Pios are. Any way we could also log the CPU’s internal temperature?
Bests! ![]()
It is logged! You can see it in the “detailed” view of the Logs page. It only measures it every ~6 hours however.
Yahu! thanks Cameron
