Error with experiment profile : "why am I here" when I try to add an automation
Hi,
I tried to write an experiment profile and when I ran it, had the following error : “why am I here”.
After an investigation, it seems that it comes from : pioreactor/actions/leader/experiment_profile.py line 446.
In facts, I try to add an automation and update it in my profile and this is probably the breaking point. I even tried to run one of the example profile (31_repeated_temperature_cycle) and had the same error so I guess there were a recent change to identify if an action in a profile is acceptable or not.
Here is my profile with the problematic part:
temperature_automation:
  actions:
          - type: update
            hours_elapsed: 2.0
            options:
              target_temperature: 32.
          - type: update
            hours_elapsed: 4.0
            options:
              target_temperature: 33.
          - type: update
            hours_elapsed: 6.0
            options:
              target_temperature: 34.
          - type: update
            hours_elapsed: 8.0
            options:
              target_temperature: 35.
          - type: update
            hours_elapsed: 10.0
            options:
              target_temperature: 36.
My software is up to date.
Hello!
Ah, I think you found a bug =(
This is a bit embarrassing as it kinda affects all automations in experiment profiles. I’ll fix and send you a new release you can use to update your Pioreactor.
Hi @elielD,
Available is a new “development” release that should fix that profile problem. You can download it here: https://github.com/Pioreactor/pioreactor/releases/download/24.3.6rc1/release_24.3.6rc1.zip
Here’s how you can update your software with it: Updating the Pioreactor software | Pioreactor Docs
Let me know if that doesn’t work for you!
Thank you very much @CamDavidsonPilon !
It works for me.
