Hello, i am a new user of the Pioreactor setup i run my first experiment and now i am trying to extract the data but i keep getting this message: “Server error occurred. Check UI logs.”
And on the UI logs:
[32m2023-12-21T19:02:36+0100 INFO [export_experiment_data] Starting export of tables: pioreactor_unit_activity_data, od_readings.e[0m Traceback (most recent call last): File “/usr/local/bin/pio”, line 8, in sys.exit(pio()) ^^^^^ File “/usr/local/lib/python3.11/dist-packages/click/core.py”, line 1157, in call return self.main(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/local/lib/python3.11/dist-packages/click/core.py”, line 1078, in main rv = self.invoke(ctx) ^^^^^^^^^^^^^^^^ File “/usr/local/lib/python3.11/dist-packages/click/core.py”, line 1688, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/local/lib/python3.11/dist-packages/click/core.py”, line 1688, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/local/lib/python3.11/dist-packages/click/core.py”, line 1434, in invoke return ctx.invoke(self.callback, **ctx.params) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/local/lib/python3.11/dist-packages/click/core.py”, line 783, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/local/lib/python3.11/dist-packages/pioreactor/actions/leader/export_experiment_data.py”, line 165, in click_export_experiment_data export_experiment_data(experiment, output, partition_by_unit, tables) File “/usr/local/lib/python3.11/dist-packages/pioreactor/actions/leader/export_experiment_data.py”, line 73, in export_experiment_data with zipfile.ZipFile(output, mode=“w”, compression=zipfile.ZIP_DEFLATED) as zf, closing( ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File “/usr/lib/python3.11/zipfile.py”, line 1281, in init self.fp = io.open(file, filemode) ^^^^^^^^^^^^^^^^^^^^^^^ FileNotFoundError: [Errno 2] No such file or directory: ‘/var/www/pioreactorui/static/exports/export_Demo experiment_20231221190235.zip’
Not sure if related: my growth curve looked fantastic when i checked 12h in, but after i had navigated to a different tab of the UI and then returned to the Overview it was not there anymore, only a few OD measurements were shown. And then again a few hours later the datapoints collected after that incident looked nice and smooth and when i refreshed the page they were gone.
Any idea what’s the problem?
