Hey,
so the export did unfortunately not work. The error seems to indicate there is no space, however it is one of the first experiments I am running on these, I only got them in December. Do I need to upgrade the SD card or is there a software workaround to this. I have attached the logs.
Thank you very much for the help!
Best,
Paul
pioreactor@pioreactor01:~ $ pio run export_experiment_data --output /run/pioreactor/exports/activity_data.zip --dataset-name pioreactor_unit_activity_data --experiment ‘Test growth M9’ --partition-by-unit --partition-by-experiment
2026-01-09T09:53:25+0100 INFO [export_experiment_data] Starting export of dataset: pioreactor_unit_activity_data to /run/pioreactor/exports/activity_data.zip.
2026-01-09T09:53:25+0100 DEBUG [export_experiment_data] SELECT 1 FROM sqlite_master WHERE (type=‘table’ or type=‘view’) and name = ‘pioreactor_unit_activity_data’
2026-01-09T09:53:25+0100 DEBUG [export_experiment_data] SELECT T., strftime(‘%Y-%m-%d %H:%M:%f’, T.timestamp, ‘localtime’) as timestamp_localtime, (unixepoch(T.timestamp) - unixepoch(E.created_at))/3600.0 as hours_since_experiment_created FROM (pioreactor_unit_activity_data) T JOIN experiments E ON E.experiment = T.experiment WHERE T.experiment IN (‘Test growth M9’) ORDER BY T.timestamp
2026-01-09T09:54:04+0100 DEBUG [export_experiment_data] Exported 10000 rows…
2026-01-09T09:54:04+0100 DEBUG [export_experiment_data] Exported 20000 rows…
2026-01-09T09:54:05+0100 DEBUG [export_experiment_data] Exported 30000 rows…
2026-01-09T09:54:05+0100 DEBUG [export_experiment_data] Exported 40000 rows…
2026-01-09T09:54:06+0100 DEBUG [export_experiment_data] Exported 50000 rows…
2026-01-09T09:54:06+0100 DEBUG [export_experiment_data] Exported 60000 rows…
2026-01-09T09:54:06+0100 DEBUG [export_experiment_data] Exported 70000 rows…
2026-01-09T09:54:07+0100 DEBUG [export_experiment_data] Exported 80000 rows…
2026-01-09T09:54:07+0100 DEBUG [export_experiment_data] Exported 90000 rows…
2026-01-09T09:54:08+0100 DEBUG [export_experiment_data] Exported 100000 rows…
2026-01-09T09:54:08+0100 DEBUG [export_experiment_data] Exported 110000 rows…
2026-01-09T09:54:08+0100 DEBUG [export_experiment_data] Exported 120000 rows…
2026-01-09T09:54:09+0100 DEBUG [export_experiment_data] Exported 130000 rows…
2026-01-09T09:54:09+0100 DEBUG [export_experiment_data] Exported 140000 rows…
2026-01-09T09:54:10+0100 DEBUG [export_experiment_data] Exported 150000 rows…
2026-01-09T09:54:10+0100 DEBUG [export_experiment_data] Exported 160000 rows…
2026-01-09T09:54:10+0100 DEBUG [export_experiment_data] Exported 170000 rows…
2026-01-09T09:54:11+0100 DEBUG [export_experiment_data] Exported 180000 rows…
2026-01-09T09:54:11+0100 DEBUG [export_experiment_data] Exported 190000 rows…
2026-01-09T09:54:12+0100 DEBUG [export_experiment_data] Exported 200000 rows…
2026-01-09T09:54:12+0100 DEBUG [export_experiment_data] Exported 210000 rows…
2026-01-09T09:54:12+0100 DEBUG [export_experiment_data] Exported 220000 rows…
2026-01-09T09:54:13+0100 DEBUG [export_experiment_data] Exported 230000 rows…
2026-01-09T09:54:13+0100 DEBUG [export_experiment_data] Exported 240000 rows…
2026-01-09T09:54:14+0100 DEBUG [export_experiment_data] Exported 250000 rows…
2026-01-09T09:54:14+0100 DEBUG [export_experiment_data] Exported 260000 rows…
2026-01-09T09:54:14+0100 DEBUG [export_experiment_data] Exported 270000 rows…
2026-01-09T09:54:15+0100 DEBUG [export_experiment_data] Exported 280000 rows…
2026-01-09T09:54:15+0100 DEBUG [export_experiment_data] Exported 290000 rows…
2026-01-09T09:54:16+0100 DEBUG [export_experiment_data] Exported 300000 rows…
2026-01-09T09:54:16+0100 DEBUG [export_experiment_data] Exported 310000 rows…
2026-01-09T09:54:17+0100 DEBUG [export_experiment_data] Exported 320000 rows…
2026-01-09T09:54:17+0100 DEBUG [export_experiment_data] Exported 330000 rows…
2026-01-09T09:54:17+0100 DEBUG [export_experiment_data] Exported 340000 rows…
2026-01-09T09:54:18+0100 DEBUG [export_experiment_data] Exported 350000 rows…
2026-01-09T09:54:18+0100 DEBUG [export_experiment_data] Exported 360000 rows…
2026-01-09T09:54:18+0100 DEBUG [export_experiment_data] Exported 370000 rows…
2026-01-09T09:54:19+0100 DEBUG [export_experiment_data] Exported 380000 rows…
2026-01-09T09:54:19+0100 DEBUG [export_experiment_data] Exported 390000 rows…
2026-01-09T09:54:19+0100 DEBUG [export_experiment_data] Exported 400000 rows…
2026-01-09T09:54:20+0100 DEBUG [export_experiment_data] Exported 410000 rows…
2026-01-09T09:54:20+0100 DEBUG [export_experiment_data] Exported 420000 rows…
2026-01-09T09:54:21+0100 DEBUG [export_experiment_data] Exported 430000 rows…
2026-01-09T09:54:21+0100 DEBUG [export_experiment_data] Exported 440000 rows…
2026-01-09T09:54:21+0100 DEBUG [export_experiment_data] Exported 450000 rows…
2026-01-09T09:54:22+0100 DEBUG [export_experiment_data] Exported 460000 rows…
2026-01-09T09:54:22+0100 DEBUG [export_experiment_data] Exported 470000 rows…
2026-01-09T09:54:22+0100 DEBUG [export_experiment_data] Exported 480000 rows…
2026-01-09T09:54:23+0100 DEBUG [export_experiment_data] Exported 490000 rows…
2026-01-09T09:54:23+0100 DEBUG [export_experiment_data] Exported 500000 rows…
2026-01-09T09:54:23+0100 DEBUG [export_experiment_data] Exported 510000 rows…
2026-01-09T09:54:24+0100 DEBUG [export_experiment_data] Exported 520000 rows…
2026-01-09T09:54:24+0100 DEBUG [export_experiment_data] Exported 530000 rows…
2026-01-09T09:54:25+0100 DEBUG [export_experiment_data] Exported 540000 rows…
2026-01-09T09:54:25+0100 DEBUG [export_experiment_data] Exported 550000 rows…
2026-01-09T09:54:25+0100 DEBUG [export_experiment_data] Exported 560000 rows…
2026-01-09T09:54:26+0100 DEBUG [export_experiment_data] Exported 570000 rows…
2026-01-09T09:54:26+0100 DEBUG [export_experiment_data] Exported 580000 rows…
2026-01-09T09:54:26+0100 DEBUG [export_experiment_data] Exported 590000 rows…
2026-01-09T09:54:27+0100 DEBUG [export_experiment_data] Exported 600000 rows…
2026-01-09T09:54:27+0100 DEBUG [export_experiment_data] Exported 610000 rows…
2026-01-09T09:54:27+0100 DEBUG [export_experiment_data] Exported 620000 rows…
2026-01-09T09:54:28+0100 DEBUG [export_experiment_data] Exported 630000 rows…
2026-01-09T09:54:28+0100 DEBUG [export_experiment_data] Exported 640000 rows…
2026-01-09T09:54:28+0100 DEBUG [export_experiment_data] Exported 650000 rows…
2026-01-09T09:54:29+0100 DEBUG [export_experiment_data] Exported 660000 rows…
2026-01-09T09:54:29+0100 DEBUG [export_experiment_data] Exported 670000 rows…
2026-01-09T09:54:30+0100 DEBUG [export_experiment_data] Exported 680000 rows…
2026-01-09T09:54:30+0100 DEBUG [export_experiment_data] Exported 690000 rows…
2026-01-09T09:54:30+0100 DEBUG [export_experiment_data] Exported 700000 rows…
2026-01-09T09:54:31+0100 DEBUG [export_experiment_data] Exported 710000 rows…
2026-01-09T09:54:31+0100 DEBUG [export_experiment_data] Exported 720000 rows…
2026-01-09T09:54:31+0100 DEBUG [export_experiment_data] Exported 730000 rows…
2026-01-09T09:54:32+0100 DEBUG [export_experiment_data] Exported 740000 rows…
2026-01-09T09:54:32+0100 DEBUG [export_experiment_data] Exported 750000 rows…
2026-01-09T09:54:32+0100 DEBUG [export_experiment_data] Exported 760000 rows…
2026-01-09T09:54:33+0100 DEBUG [export_experiment_data] Exported 770000 rows…
2026-01-09T09:54:33+0100 DEBUG [export_experiment_data] Exported 780000 rows…
2026-01-09T09:54:33+0100 DEBUG [export_experiment_data] Exported 790000 rows…
2026-01-09T09:54:34+0100 DEBUG [export_experiment_data] Exported 800000 rows…
2026-01-09T09:54:34+0100 DEBUG [export_experiment_data] Exported 810000 rows…
2026-01-09T09:54:35+0100 DEBUG [export_experiment_data] Exported 820000 rows…
2026-01-09T09:54:35+0100 DEBUG [export_experiment_data] Exported 830000 rows…
2026-01-09T09:54:35+0100 DEBUG [export_experiment_data] Exported 840000 rows…
2026-01-09T09:54:36+0100 DEBUG [export_experiment_data] Exported 850000 rows…
2026-01-09T09:54:36+0100 DEBUG [export_experiment_data] Exported 860000 rows…
2026-01-09T09:54:36+0100 DEBUG [export_experiment_data] Exported 870000 rows…
2026-01-09T09:54:37+0100 DEBUG [export_experiment_data] Exported 880000 rows…
2026-01-09T09:54:37+0100 DEBUG [export_experiment_data] Exported 890000 rows…
2026-01-09T09:54:37+0100 DEBUG [export_experiment_data] Exported 900000 rows…
2026-01-09T09:54:38+0100 DEBUG [export_experiment_data] Exported 910000 rows…
2026-01-09T09:54:38+0100 DEBUG [export_experiment_data] Exported 920000 rows…
2026-01-09T09:54:39+0100 DEBUG [export_experiment_data] Exported 930000 rows…
2026-01-09T09:54:39+0100 DEBUG [export_experiment_data] Exported 940000 rows…
2026-01-09T09:54:39+0100 DEBUG [export_experiment_data] Exported 950000 rows…
2026-01-09T09:54:40+0100 DEBUG [export_experiment_data] Exported 960000 rows…
2026-01-09T09:54:40+0100 DEBUG [export_experiment_data] Exported 970000 rows…
2026-01-09T09:54:40+0100 DEBUG [export_experiment_data] Exported 980000 rows…
2026-01-09T09:54:41+0100 DEBUG [export_experiment_data] Exported 990000 rows…
2026-01-09T09:54:41+0100 DEBUG [export_experiment_data] Exported 1000000 rows…
2026-01-09T09:54:41+0100 DEBUG [export_experiment_data] Exported 1010000 rows…
2026-01-09T09:54:42+0100 DEBUG [export_experiment_data] Exported 1020000 rows…
2026-01-09T09:54:42+0100 DEBUG [export_experiment_data] Exported 1030000 rows…
2026-01-09T09:54:42+0100 DEBUG [export_experiment_data] Exported 1040000 rows…
2026-01-09T09:54:43+0100 DEBUG [export_experiment_data] Exported 1050000 rows…
2026-01-09T09:54:43+0100 DEBUG [export_experiment_data] Exported 1060000 rows…
2026-01-09T09:54:44+0100 DEBUG [export_experiment_data] Exported 1070000 rows…
2026-01-09T09:54:44+0100 DEBUG [export_experiment_data] Exported 1080000 rows…
2026-01-09T09:54:44+0100 DEBUG [export_experiment_data] Exported 1090000 rows…
2026-01-09T09:54:45+0100 DEBUG [export_experiment_data] Exported 1100000 rows…
2026-01-09T09:54:45+0100 DEBUG [export_experiment_data] Exported 1110000 rows…
2026-01-09T09:54:45+0100 DEBUG [export_experiment_data] Exported 1120000 rows…
2026-01-09T09:54:46+0100 DEBUG [export_experiment_data] Exported 1130000 rows…
2026-01-09T09:54:46+0100 DEBUG [export_experiment_data] Exported 1140000 rows…
2026-01-09T09:54:46+0100 DEBUG [export_experiment_data] Exported 1150000 rows…
2026-01-09T09:54:47+0100 DEBUG [export_experiment_data] Exported 1160000 rows…
2026-01-09T09:54:47+0100 DEBUG [export_experiment_data] Exported 1170000 rows…
2026-01-09T09:54:48+0100 DEBUG [export_experiment_data] Exported 1180000 rows…
2026-01-09T09:54:48+0100 DEBUG [export_experiment_data] Exported 1190000 rows…
2026-01-09T09:54:48+0100 DEBUG [export_experiment_data] Exported 1200000 rows…
2026-01-09T09:54:49+0100 DEBUG [export_experiment_data] Exported 1210000 rows…
2026-01-09T09:54:49+0100 DEBUG [export_experiment_data] Exported 1220000 rows…
2026-01-09T09:54:49+0100 DEBUG [export_experiment_data] Exported 1230000 rows…
2026-01-09T09:54:50+0100 DEBUG [export_experiment_data] Exported 1240000 rows…
2026-01-09T09:54:50+0100 DEBUG [export_experiment_data] Exported 1250000 rows…
2026-01-09T09:54:50+0100 DEBUG [export_experiment_data] Exported 1260000 rows…
2026-01-09T09:54:51+0100 DEBUG [export_experiment_data] Exported 1270000 rows…
2026-01-09T09:54:51+0100 DEBUG [export_experiment_data] Exported 1280000 rows…
2026-01-09T09:54:51+0100 DEBUG [export_experiment_data] Exported 1290000 rows…
2026-01-09T09:54:52+0100 DEBUG [export_experiment_data] Exported 1300000 rows…
2026-01-09T09:54:52+0100 DEBUG [export_experiment_data] Exported 1310000 rows…
2026-01-09T09:54:53+0100 DEBUG [export_experiment_data] Exported 1320000 rows…
2026-01-09T09:54:53+0100 DEBUG [export_experiment_data] Exported 1330000 rows…
2026-01-09T09:54:53+0100 DEBUG [export_experiment_data] Exported 1340000 rows…
2026-01-09T09:54:54+0100 DEBUG [export_experiment_data] Exported 1350000 rows…
2026-01-09T09:54:54+0100 DEBUG [export_experiment_data] Exported 1360000 rows…
2026-01-09T09:54:54+0100 DEBUG [export_experiment_data] Exported 1370000 rows…
2026-01-09T09:54:55+0100 DEBUG [export_experiment_data] Exported 1380000 rows…
2026-01-09T09:54:55+0100 DEBUG [export_experiment_data] Exported 1390000 rows…
2026-01-09T09:54:55+0100 DEBUG [export_experiment_data] Exported 1400000 rows…
2026-01-09T09:54:56+0100 DEBUG [export_experiment_data] Exported 1410000 rows…
2026-01-09T09:54:56+0100 DEBUG [export_experiment_data] Exported 1420000 rows…
2026-01-09T09:54:56+0100 DEBUG [export_experiment_data] Exported 1430000 rows…
2026-01-09T09:54:57+0100 DEBUG [export_experiment_data] Exported 1440000 rows…
2026-01-09T09:54:57+0100 DEBUG [export_experiment_data] Exported 1450000 rows…
2026-01-09T09:54:58+0100 DEBUG [export_experiment_data] Exported 1460000 rows…
2026-01-09T09:54:58+0100 DEBUG [export_experiment_data] Exported 1470000 rows…
2026-01-09T09:54:58+0100 DEBUG [export_experiment_data] Exported 1480000 rows…
2026-01-09T09:54:59+0100 DEBUG [export_experiment_data] Exported 1490000 rows…
2026-01-09T09:54:59+0100 DEBUG [export_experiment_data] Exported 1500000 rows…
2026-01-09T09:54:59+0100 DEBUG [export_experiment_data] Exported 1500199 rows from pioreactor_unit_activity_data.
File “/usr/lib/python3.13/zipfile/init.py”, line 1908, in write
shutil.copyfileobj(src, dest, 10248)
File “/usr/lib/python3.13/shutil.py”, line 204, in copyfileobj
fdst_write(buf)
File “/usr/lib/python3.13/zipfile/init.py”, line 1252, in write
self._fileobj.write(data)
OSError: [Errno 28] No space left on device
During handling of the above exception, another exception occurred:
File “/opt/pioreactor/venv/lib/python3.13/site-packages/pioreactor/actions/leader/export_experiment_data.py”, line 340, in export_experiment_data
zf.write(path_to_file, arcname=f"{dataset_name}/{path_to_file.name}")
File “/usr/lib/python3.13/zipfile/init.py”, line 1907, in write
with open(filename, “rb”) as src, self.open(zinfo, ‘w’) as dest:
File “/usr/lib/python3.13/zipfile/init.py”, line 1290, in close
self._fileobj.seek(self._zinfo.header_offset)
File “/usr/lib/python3.13/zipfile/init.py”, line 2005, in close
self.fp.seek(self.start_dir)
File “/opt/pioreactor/venv/bin/pio”, line 7, in
sys.exit(pio())
File “/opt/pioreactor/venv/lib/python3.13/site-packages/click/core.py”, line 1157, in call
File “/opt/pioreactor/venv/lib/python3.13/site-packages/click/core.py”, line 1078, in main
File “/opt/pioreactor/venv/lib/python3.13/site-packages/click/core.py”, line 1688, in invoke
File “/opt/pioreactor/venv/lib/python3.13/site-packages/click/core.py”, line 1434, in invoke
File “/opt/pioreactor/venv/lib/python3.13/site-packages/click/core.py”, line 783, in invoke
File “/opt/pioreactor/venv/lib/python3.13/site-packages/pioreactor/actions/leader/export_experiment_data.py”, line 361, in click_export_experiment_data
export_experiment_data(
experiment, dataset_name, output, start_time, end_time, partition_by_unit, partition_by_experiment
File “/opt/pioreactor/venv/lib/python3.13/site-packages/pioreactor/actions/leader/export_experiment_data.py”, line 222, in export_experiment_data
with zipfile.ZipFile(output, mode=“w”, compression=zipfile.ZIP_DEFLATED) as zf, closing(
File “/usr/lib/python3.13/zipfile/init.py”, line 1428, in exit
self.close()
File “/usr/lib/python3.13/zipfile/init.py”, line 2010, in close
self._fpclose(fp)
File “/usr/lib/python3.13/zipfile/init.py”, line 2110, in _fpclose
fp.close()
