This error occurs when I made some changes to the config file in http://pioreactor1.local/config and then press “save”
I was adding some charts, and sometimes it seems like the changes go through, but I’m not sure if they are going through every time. Despite these errors, I am able to add new charts and .yamls and see them displayed on the main page.
tail -n 50 /var/log/pioreactorui.log
2023-03-05T12:59:52-0800 [huey.consumer.Worker] ERROR Unhandled error during execution of task ca528aff-991a-44ad-ae3f-cb805828c890.
File "/usr/local/lib/python3.9/dist-packages/huey/consumer.py", line 117, in loop
self.huey.execute(task, now)
File "/usr/local/lib/python3.9/dist-packages/huey/api.py", line 362, in execute
return self._execute(task, timestamp)
File "/usr/local/lib/python3.9/dist-packages/huey/api.py", line 407, in _execute
self.put_result(task.id, task_value)
File "/usr/local/lib/python3.9/dist-packages/huey/api.py", line 323, in put_result
return self.storage.put_data(key, self.serializer.serialize(data),
File "/usr/local/lib/python3.9/dist-packages/huey/storage.py", line 793, in put_data
self.sql('insert or replace into kv (queue, key, value) '
File "/usr/local/lib/python3.9/dist-packages/huey/storage.py", line 670, in sql
curs.execute(query, params or ())
sqlite3.DatabaseError: database disk image is malformed
2023-03-05T13:00:50-0800 [pioreactorui] ERROR sync-configs timed out.
2023-03-05T13:05:10-0800 [huey.consumer.Worker] ERROR Unhandled error during execution of task 29ea07d3-d1f0-4855-9c95-03b30a5d66d9.
2023-03-05T13:06:08-0800 [pioreactorui] ERROR sync-configs timed out.
2023-03-05T13:18:36-0800 [huey.consumer.Worker] ERROR Unhandled error during execution of task 119e9f45-1f5f-4dd9-ad22-4735e22a2d21.
2023-03-05T13:19:34-0800 [pioreactorui] ERROR sync-configs timed out.
