Hello,
I just updated all my cluster to the last software version through pio update, by ssh’s each of the reactors. App updated to version 25.3.5 and UI to version 25.3.31.
However, I cannot see my cluster anymore in the UI, the experiments and calibration files are gone. When using pio workers status in the leader, I get the following:
pioreactor@Leader1:~ $ pio workers status
Name Is leader? IP address State Active? Reachable? Version Experiment
sys.exit(pio())
File "/usr/local/lib/python3.11/dist-packages/pioreactor/cluster_management/__init__.py", line 294, in cluster_status
for result in results:
File "/usr/lib/python3.11/concurrent/futures/_base.py", line 619, in result_iterator
yield _result_or_cancel(fs.pop())
File "/usr/lib/python3.11/concurrent/futures/_base.py", line 317, in _result_or_cancel
return fut.result(timeout)
File "/usr/lib/python3.11/concurrent/futures/_base.py", line 449, in result
return self.__get_result()
File "/usr/lib/python3.11/concurrent/futures/_base.py", line 401, in __get_result
raise self._exception
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
result = self.fn(*self.args, **self.kwargs)
File "/usr/local/lib/python3.11/dist-packages/pioreactor/cluster_management/__init__.py", line 265, in display_data_for
hostname, is_active = worker["pioreactor_unit"], worker["is_active"]
TypeError: string indices must be integers, not 'str'
Could I get some help with this?
Thanks in advance!
