Local access point properties cannot be copied
Hi everone,
I am having problem with connecting to the local access point, which I think is caused during the step where I try to add the local_access_point file to the flashed SD card. Does anyone know if getting local_access_point has properties that cannot be copied pop-up window is normal?
The issue seemed to be a Windows software issue and I managed to connect to the local access point, so I would say the interrupted action pop-up is not an issue!
Good to know! I’ve not encountered that, but I’ll add it to our docs.
