Monitor and Mqtt failed
Hi all,
My leader recently failed when both the monitor and mqtt_to_db_streaming jobs both are listed as OFF. This has caused my connection to the UI with my leader to be lost, and the Pio no longer flashes a blue led light.
I’ve attached the log message I received, and am curious if anyone else has had these issues/may have a solution!
Thank you!
● pioreactor_startup_run@monitor.service loaded failed failed >
● pioreactor_startup_run@mqtt_to_db_streaming.service loaded failed failed
Hi @HillsLaura,
Hm, can you check the following?
systemctl status pioreactor_startup_run@monitor.service
Do you see any errors in the output?
