Hi!
I have problems with the morbidostat.py plugin (automation-examples/dosing/morbidostat.py at main · Pioreactor/automation-examples · GitHub). More specifically, with a slight variation of it, which takes into account the OD instead of the nOD. This is the code:
GNU nano 7.2 morbidostat.py
# -*- coding: utf-8 -*-
class Morbidostat(DosingAutomationJobContrib):
As defined in Toprak 2013., keep cell density below and threshold using chemical means. The conc.
of the chemical is diluted slowly over time, allowing the microbes to recover.
automation_name = "morbidostat"
published_settings = {
"volume": {"datatype": "float", "settable": True, "unit": "mL"},
"target_od": {"datatype": "float", "settable": True, "unit": "AU"},
def __init__(self, target_od: float | str, volume: float | str, **kwargs):
super(Morbidostat, self).__init__(**kwargs)
self.target_od = float(target_od)
self.volume = float(volume)
def execute(self) -> events.AutomationEvent:
if self.previous_od is None:
return events.NoEvent("skip first event to wait for OD readings.")
elif (
self.latest_od >= self.target_od
self.latest_od >= self.previous_od
# if we are above the threshold, and growth rate is greater than dilution rate
# the second condition is an approximation of this.
self.execute_io_action(alt_media_ml=self.volume, waste_ml=self.volume)
return events.AddAltMediaEvent(
f"latest OD, {self.latest_od:.2f} >= Target OD, {self.target_od:.2f} and Latest OD, {self.latest_od:.>
else:
self.execute_io_action(media_ml=self.volume, waste_ml=self.volume)
return events.DilutionEvent(
f"latest OD, {self.latest_od:.2f} < Target OD, {self.target_od:.2f} or Latest OD, {self.latest_od:.2f>
In previous versions of pioreactor, the plugin variation worked fine. However, after upgrading to 25.5.22, it reports the following problem:
'>=“ not supported between instances of 'dict” and “float”"
I understand the problem, but I don’t know how to fix it. I guess it will affect this part of the code where the OD is compared with the threshold value.
I tried to solve it by cascading the variable such that:
float(self.latest_od) >= float(self.target_od)
float(self.latest_od) >=float(self.previous_od)
but I get this other error:
float() argument must be a string or a real number, not “dict”.
More information:
Software version (all pios): 25.5.22
File path morbidostat.py (all pios): /home/pioreactor/.pioreactor/plugins/
File path morbidostat.yaml (just in leader):/home/pioreactor/.pioreactor/plugins/ui/contrib/automations/dosing/
yaml file:
display_name: Morbidostat (Classic)
automation_name: morbidostat
description: >
As defined in Toprak 2013., keep cell density below and threshold using chemical means. The concentration of the che>
fields:
- key: target_od
default: 0.2
unit: AU
label: Target OD
type: numeric
- key: volume
default: 1.0
unit: mL
label: Volume
type: numeric
- key: duration
default: 12
unit: min
label: Time between check
disabled: False
type: numeric
Any solution? Some colleagues are visiting us for a week to learn how the pyoreactor works and the experiment has gone down the drain ![]()
