Mqtt to db streaming warning "should be running on leader"
“should be running on leader”. We then check it in the command line and it says that it’s working. But maybe this might cause issues at some point.
Hi @rls333, it could be a race-condition (example: we check before mqtt_to_db_streaming is finished setting up). As a reassurance, you can visit the Leader page (under Inventory) and confirm mqtt_to_db_streaming is on there, too.
