I did a fresh install of the 25.9.18 image on all 8 of our pioreactors. When we went to calibrate the pumps and OD we got the errors below and installed libopenblas-dev and libopenblas-base.
We had to do that on everyone pioreactor though and I can’t find ws.conf on every pioreactor, just the two assigned to one student group. I don’t know what they may have installed, they can’t remember or communicate it to me.
pio calibrations set-active --device media_pump --name <calibration_name>
Reading to start stirring? [Y/n]: Y
Starting stirring and blocking until near target RPM.
Starting OD recordings.
File “/usr/local/lib/python3.11/dist-packages/numpy/_core/init.py”, line 22, in
from . import multiarray
File “/usr/local/lib/python3.11/dist-packages/numpy/_core/multiarray.py”, line 11, in
from . import _multiarray_umath, overrides
ImportError: libopenblas.so.0: cannot open shared object file: No such file or directory
The above exception was the direct cause of the following exception:
File “/usr/local/lib/python3.11/dist-packages/numpy/init.py”, line 112, in
from numpy.config import show_config
File “/usr/local/lib/python3.11/dist-packages/numpy/config.py”, line 4, in
from numpy._core._multiarray_umath import (
File “/usr/local/lib/python3.11/dist-packages/numpy/_core/init.py”, line 48, in
raise ImportError(msg) from exc
ImportError:
IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE!
Importing the numpy C-extensions failed. This error can happen for
many reasons, often due to issues with your setup or how NumPy was
installed.
We have compiled some common reasons and troubleshooting tips at:
https://numpy.org/devdocs/user/troubleshooting-importerror.html
Please note and check the following:
- The Python version is: Python3.11 from “/usr/bin/python3”
- The NumPy version is: “2.3.3”
and make sure that they are the versions you expect.
Please carefully study the documentation linked above for further help.
Original error was: libopenblas.so.0: cannot open shared object file: No such file or directory
File “/usr/local/bin/pio”, line 7, in
sys.exit(pio())
File “/usr/local/lib/python3.11/dist-packages/click/decorators.py”, line 33, in new_func
return f(get_current_context(), *args, **kwargs)
File “/usr/local/lib/python3.11/dist-packages/pioreactor/cli/calibrations.py”, line 126, in run_calibration
calibration_struct = assistant().run(
File “/usr/local/lib/python3.11/dist-packages/pioreactor/calibrations/init.py”, line 70, in run
return run_od_calibration()
File “/usr/local/lib/python3.11/dist-packages/pioreactor/calibrations/od_calibration_using_standards.py”, line 290, in run_od_calibration
inferred_od600s, voltages = start_recording_standards(st, pd_channel)
File “/usr/local/lib/python3.11/dist-packages/pioreactor/calibrations/od_calibration_using_standards.py”, line 182, in start_recording_standards
with start_od_reading(
File “/usr/local/lib/python3.11/dist-packages/pioreactor/background_jobs/od_reading.py”, line 1367, in start_od_reading
return ODReader(
File “/usr/local/lib/python3.11/dist-packages/pioreactor/background_jobs/base.py”, line 107, in call
obj = type.call(cls, *args, **kwargs)
File “/usr/local/lib/python3.11/dist-packages/pioreactor/background_jobs/base.py”, line 264, in wrapped_init
orig_init(self, *args, **kwargs)
File “/usr/local/lib/python3.11/dist-packages/pioreactor/background_jobs/od_reading.py”, line 944, in init
on_reading = self.adc_reader.tune_adc() # determine best gain, max-signal, etc.
File “/usr/local/lib/python3.11/dist-packages/pioreactor/background_jobs/od_reading.py”, line 233, in tune_adc
self.most_appropriate_AC_hz = self.determine_most_appropriate_AC_hz(
File “/usr/local/lib/python3.11/dist-packages/pioreactor/background_jobs/od_reading.py”, line 566, in determine_most_appropriate_AC_hz
argmin_freq1 = _compute_best_freq(timestamps[channel], aggregated_signals[channel])
File “/usr/local/lib/python3.11/dist-packages/pioreactor/background_jobs/od_reading.py”, line 558, in _compute_best_freq
_, AIC = self._sin_regression_with_known_freq(timestamps, aggregated_signals, freq=freq)
File “/usr/local/lib/python3.11/dist-packages/pioreactor/background_jobs/od_reading.py”, line 362, in _sin_regression_with_known_freq
import numpy as np
File “/usr/local/lib/python3.11/dist-packages/numpy/init.py”, line 117, in
ImportError: Error importing numpy: you should not try to import numpy from
its source directory; please exit the numpy source tree, and relaunch
your python interpreter from there.
