New Pioreactor aeration kit
:wave: I’m excited to introduce the new Pioreactor Aeration Kit! It’s a entirely new way to provide active aeration to your cultures. The kit has a controllable 12V air pump, an inline humidifier, and tiny sparger that fits nicely into either the 20ml or 40ml vial.
Read more about it here:
This is awesome! Can you give us any more details about the sparger?
Sure. It’s a SS316 sparger with 15-20µm pore size, sized OD 4.8mm * H 11.0mm (without the barb). It contains no glues or additives (it’s one solid piece). I’ll try to get video today or tomorrow to show it in action.
It’s individually available here: Sintered sparger with 1/16" barb | Pioreactor
This is at 80% power
I can see also an easter egg for a new cap release (P2) which is not in the shop? will that become available as well?
Yes, I think we just need some photos first
I currently working on my thesis project utilizing 1 unit pioreactor to model microalgae culture.
now for the aeration kit, can you elaborate specs of the pump you’re using?
like LPM, HG, kPA, dimension
worried to blow it off
Hi @zeb7737
Here are some measurements from the manufacturer.
dimensions: Approximately 41 × 24 × 41 mm
positive pressure capability: Approximately 80 kPa (600 mmHg)
airflow: Approximately 1.0–1.5 L/min (unrestricted)
However, because we operate the pump at 5V rather than 12V, the actual airflow and pressure capability are lower. We don’t currently have verified flow and pressure ratings at 5V.
thanks @CamDavidsonPilon for the information
your pioreactor is amazing!
hi @CamDavidsonPilon
I’ve got more ideas to mod my pioreactor setup
I wonder about the power supply and data logging
may I DM you?
Yes of course!
