23.1.3
- Fix
dosing_events
table not be populated caused by an incorrect SQLite3 trigger. - Running a pump continuously will produce MQTT events with new timestamps (previously it was the same timestamp.)
- Faster loading for some pages in Pioreactor UI
- Fix for RaspAP not turning on when requested using
local_access_point
file - Caching in Pioreactor UI is improved.
- systemd services should boot in an even better order
- Bug fixes
- New 64bit images are available on the CustoPiZer release page. Default is still 32bit until more testing can be done.
Problems? Let me know here or at cam@pioreactor.com
