23.11.08
fix bug in
timeoutinStirrer.block_until_rpm_is_close_to_targetthat wasn’t using time correctly. -
Workers can now also be the local-access-point (aka the “router” in a network). Previously only leaders could.
Experiment profiles now support a
logdirective with some dynamic templating:- type: log hours_elapsed: 0.025 options: message: "{job} increasing to 800 RPM" # alerts the message: "stirring increasing to 800 RPM"See full example here.
Experiment profiles now supports changing LEDs like any other job (i.e. they can use
start,updateandstopdirectives). See example here. -
Experiment profile clean up. I think there are less bugs!
pio clear_cachenow has anas_intoption to look for ints - useful when clearing caches with ints as keys. -
fix issue where if an extra config.ini was provided in the /boot dir before a worker startup, adding the worker to a cluster would fail due to a permission issue.
potential fix for RPi 3B and RPi Zeros not connecting to hotspots: change the
prototowpain your config.ini on the Pioreactor with the local-access-point, and restart that Pioreactor. You config.ini should look like:[local_access_point] ssid=pioreactor passphrase=raspberry proto=wpaChanging to WPA does weaken the security however! It’s easier for unwanted users to get onto this wifi
A more robust solution is in the works for RPi 3B and Zeros.
Slight change to the API initialization of ADCReader. Take a look if you were using that class.
How to update?
Update guides are available here
