There was a UI-export bug in a previous version that we hotfixed in 23.11.29. Cheers!
23.11.29
- fix for exporting data from the UI
23.11.28
- Merged the turbidostat automations into one. You can either select to target nOD or target OD, but not both!
ws_url
in the configuration now requires a fully qualified url. Example:ws://...
orwss://...
.- Removed
morbidostat
dosing automation, users should try to use pid_morbidostat. The morbidostat code is still available to be added as a custom plugin here: https://github.com/Pioreactor/automation-examples/blob/main/dosing/morbidostat.py - Removed
constant_duty_cycle
temperature automation. Again, the code is available here: https://github.com/Pioreactor/automation-examples/blob/main/temperature/constant_duty_cycle.py pid_morbidostat
now explicitly uses the keyword argtarget_normalized_od
, instead oftarget_od
. It always has been nOD.
- Both “Target OD” and “Target nOD” displayed and editable in the UI.
- Previously, if the LED channel was locked (most common when OD reading was running), then any changes to the LED intensity (via the UI) would be silently rejected. This is changed: we have added retry logic that will attempt to keep changing it a few more times (hopefully to avoid the lock)
- Added some light form validation in the automations dialog in the UI.
- New environment variable to skip loading plugins,
SKIP_PLUGINS
. Useful for debugging. Ex:SKIP_PLUGINS=1 pio run stirring
- elements in the
field
array in automation yamls now can include atype
option (numeric
orstring
for now). Default isnumeric
if not specified.
Bug Fixes
- Fix experiment profile validation error
- The “Stop” button is always available now in the “Dosing” tab for “Manage all Pioreactors”.
- Fix for Ngrok remote access.
- Fixed a race condition between starting an automation and not getting OD data in time.
- The automation form in the UI for pid_morbidostat was missing
volume
, that’s been added now.
How to upgrade
See our instructions here.
