23.6.7
Highlights
Support for viewing, starting and stopping experiment profiles in the UI!
Adding manual dosing adjustment form under Dosing tab in the UI!
Everything else
- New API for experiment profiles:
pio run experiment_profile, with subcommandsexecuteandverify. So what use to bepio run execute_experiment_profile <filename>is now:pio run experiment_profile execute <filename>. Theverifysubcommand is for checking the yaml file for errors. - new leader CLI command:
pios cp <filepath>will move a file on your leader to the entire cluster. This is useful for distributing plugins and Python wheels across your workers. - plugins can now add
post_install.shandpre_uninstall.shbash scripts. - added
[stirring]optionduration_between_updates_secondsto config, default is 23.0. - PIDMorbidostat has a configuration parameter
[dosing_automation.pid_morbidostat].minimum_dosing_volume_ml(default 0.1). If a calculated volume to be dosed is less than this parameter, then it’s set to 0.0 instead. - adding
--manuallyflag to pump actions, ex:pio run add_media --ml 1 --manually. This doesn’t run the pump, but still fires a dosing event, which downstream jobs listen to (ex: saves to database, will update metrics).
Problems? Let me know here or at cam@pioreactor.com.
