24.1.26
Conditionals and expressions in experiment profiles!
- adding
ifdirectives to experiment_profiles, with dynamic expressions. See full docs here
stirring:
actions:
- type: update
hours_elapsed: 12.0
if: pio1:od_reading:od1.od > 2.0
options:
- target_rpm: 600
- adding dynamic options via expressions, see full docs here
stirring:
actions:
- type: update
hours_elapsed: 12.0
options:
- target_rpm: ${{ pio1:stirring:target_rpm * 1.1 }}
Breaking changes to experiment profiles:
the
commonblock requires ajobsblock. Previously:experiment_profile_name: demo_stirring_example metadata: author: Cam Davidson-Pilon description: common: stirring: actions: - type: start hours_elapsed: 0.0 options: target_rpm: 400.0Now:
experiment_profile_name: demo_stirring_example metadata: author: Cam Davidson-Pilon description: common: jobs: # this text is required stirring: actions: - type: start hours_elapsed: 0.0 options: target_rpm: 400.0 -
labelshas moved into thepioreactorsblock. Previously,experiment_profile_name: simple_stirring_example labels: worker1: PR-001 metadata: author: John Doe description: pioreactors: worker1: jobs: {}Now,
experiment_profile_name: simple_stirring_example metadata: author: John Doe description: pioreactors: worker1: label: PR-001 jobs: {}Related, you can’t use the label as an alias in the
pioreactorblock.Need a hand updating your profiles? Let us know, support@pioreactor.com!
- removing
ODReadings.latest_od_readingand it’s replaced byODReadings.ods. - removed the topic
pioreactor/{unit}/.../od_readings/od/{channel}. Usepioreactor/{unit}/.../od_readings/od1orpioreactor/{unit}/.../od_readings/od2. This change was made to fit more and more published data into the same format (and it makesod1andod2published settings onODReader)
ods,od1,od2now a published settings ofODReadings.- when a worker is first turned on, and pre-connected to a cluster, the LED is turned on to give some feedback to the user.
- using the 2023-12-11 RPi base image
- fixed the UI crashing if trying to edit a blank experiment profile
Experimental builds
We’ve released new 64 bit builds, and a 64 bit “headful” build. These builds are experimental, and require a RPi4, RPi5, or RPi400 due to their larger memory requirements.
- 64 bit leader-worker and worker builds will be marginally more performant, at the cost of some additional memory consumption.
- The “headful” leader-worker build allows you to attach a monitor, keyboard, mouse, etc. to the Raspberry Pi and use it as an interface for your cluster.
These builds are available only on our nightly page.
How to update:
Here’s a few methods to update your software: Updating the Pioreactor software | Pioreactor Docs
