24.2.26
Highlights
Experimental introducing outlier filtering in growth rate calculations. This is tunable with the new
ekf_outlier_std_thresholdparameter under[growth_rate_calculating.config]. To turn off outlier filtering, set this parameter to some very large number (1000s). Don’t put it less than 3.0 - that’s silly. -
With this new filtering, we can provide more reasonable values for the parameters of the growth rate Kalman filter. We previously had to artificially increase the measurement std. deviation (
obs_std) to allow for some outliers. This had the knock-on effect of hiding growth-rate changes, so we had to also increase that parameterrate_std. With better outlier protection in the model, we can move these values back. New installs will have the following parameters, and we encourage existing users to try these values if you plan to use the outlier filtering.[growth_rate_kalman] acc_std=0.0008 obs_std=1.5 od_std=0.0025 rate_std=0.1 -
added configuration for alternative mqtt brokers with the new configuration
[mqtt] username=pioreactor password=raspberry broker_address= broker_ws_port=9001 broker_port=1883 ws_protocol=ws use_tls=0
- clear the growth-rate cache with
pio run growth_rate_cacluating clear_cache - added Pioreactor specific software version to the UI: Page Pioreactors → Manage → System → Version. this requires a restart to display correctly
- new UI MQTT library. Is it faster? Maybe!
- increased the default
max_subdoseto 1.0.
- fixed a case where dosing automation IO execution would not run due to a floating point rounding error. Sorry!
- fixed a memory leak in long running dosing automations that had thousands of dosing events. Sorry!
- fixed a race condition that caused an error to occur when a software PWM channel was closed too quickly. Sorry!
- fixed bug that was partially crashing the UI if some bad syntax was entered into a custom yaml file. Sorry!
- fixed bug that was causing bad json from the server, causing empty / non-loading areas in the UI. Sorry!
- fixed
datumbug in the Overview that was crashing the UI. Sorry!
