Thanks to the testing work done by @kellyt we were able to get this new version out much faster than anticipated! Our documentation at https://docs.pioreactor.com/ is behind, and we’re updating that to reflect the (big!) changes in this release.
24.4.3
Highlights
- The Pioreactor leader can now support multiple experiments! If you have more than one Pioreactor, this change allows you to run multiple experiments simultaneously, assign Pioreactors to different experiments, and manage all experiments concurrently. No more multi-leader set ups - all you need is a single leader and multiple workers! See video here.
- Ability to delete experiments from the UI.
- Better control over your cluster, using the Inventory page in the UI.
- Ship with network configuration of local-link connections: plug in an ethernet from your Pioreactor to your computer, and after invoking
sudo nmcli c PioreactorLocalLink up, you should be able to visithttp://pioreactor.localin your browser.
- replace the
ipfile that is written to on startup with a newnetwork_info.txtfile that contains the hostname, IPv4 address, and MAC addresses. - Adding the ethernet (wired) mac address to the system tab.
- new Python module for controlling workers:
pioreactor.cluster_management - by default, for new installs, the local-access-point SSID is now
pioreactor_<hostname>. - UI performance improvements
- New database tables to handle workers (
workers) and experiments assignments (experiment_assignments). - New
pio workersCLI to mange your inventory. Trypio workers --helpto see all the commands available. - Better error messages when a self-test fails.
pio killhas new options to kill specific actions. Ex:pio kill --experiment this-exp,pio kill --job-source experiment_profile
- When a experiment profile stops early (i.e. via “stop early” in the UI), it now will halt any jobs that it started. This is a change from how they worked previously, but this new behaviour is less of a surprise to users.
pio add-pioreactor <name>is nowpio workers add <name>pio cluster-statusis nowpio workers statusutils.publish_ready_to_disconnected_statechanged names toutils.managed_lifecycleconfig.inventoryin the config.ini is no longer used. All that data is now handled in the database on the leader, and managed in the UI or CLI.pio kill <job_name>is removed, usepio kill --name <job_name>.
- fix for not being able to access
http://pioreactor.localreliably. - fix for multiple exporting datasets when selecting “All experiments”
Known bugs
- removing a Pioreactor leader from an experiment will stop any experiment profiles running that are associated to that experiment.
- some logs are not showing up in the Recent Logs table
- Pressing the button on the HAT is not showing up in the UI.
