24.5.13
We recommend you be on 24.5.1 first before upgrading to this version!
- UI chart legend’s will support more than 8 Pioreactors.
- UI chart colors are consistent across charts in the Overview.
- reduce the severity of some messages, so there will be less pop-ups in the UI.
- UI performance improvements.
- Upgraded to React 18.3.1
- Removed unused dependencies
- UI’s code sections use syntax-highlighting and other nicer features for editing yaml and ini files.
- App performance improvements
- Upgrade paho-mqtt to 2.1
- faster
pio kill - faster job start from UI
- more humane error messages.
- updated temperature inference model.
- added exponentiation
**to profile expressions. Ex:${{ pio1:growth_rate_calculating:growth_rate.growth_rate ** 0.5 }} - added
random()to profile expressions. This returns a number between 0 and 1. Ex:${{ 25 + 25 * random() }}
- fix
pio pluginsnot working on workers. - fix
enable_dodging_od=0for background jobs that can dodge OD. - fix PWM jobs not cleaning up correctly if too many jobs try to end at the same time.
- fix
pio killnot returning the correct count of jobs being killed. - fix older Pioreactor HATs, with the ADS1115 chip, not have the method
from_voltage_to_raw_precise. - fix “Manage all” not sending the correct dosing command to workers.
