23.6.27
Highlights
Update to development branches
- The UI now offers a way to upgrade to the bleeding-edge Pioreactor app and UI software, called “development”. This software is unstable (and fun!).
Better thermostat
- Improved temperature inference accuracy.
- After some testing, we’ve found that the following set of PID parameters for
temperature_automation.thermostatworks better¹ than the previous set of parameters:
Kp=3.0
Ki=0.0
Kd=4.5
This set now ships with all new installations of Pioreactor software. Existing users can update their parameters in the config.ini
¹ Better == less thermal runaways, less sensitive to shocks, similar overshoot and settling time.
Everything else
- On startup, the Raspberry Pi will write its IP address to a text file
/boot/ip. This means that if you (carefully) remove the SD card, you should be able see the IP address (hopefully it hasn’t changed). - Fixed
sourceinBackgroundJobContrib- thanks @odcambc! pio add-pioreactorwill now accept an option that is the password of the RPi being added (default:raspberry). Ex:pio add-pioreactor worker1 -p mypass- Improved some warning and error messages.
- Improved watchdog detecting and fixing “lost” Pioreactors.
- Starting to test software against Python 3.11, in anticipation of a Python 3.11 coming to Raspberry Pi OS.
- Improvements to bash scripts to make them more robust.
- Adding
pios rm <filepath>to remove a file across the cluster. - Adding
-roption topio update. Example:pio update <x> -r <repo>to install from a repo (default is Pioreactor’s repos). structs.ODCalibrationhas a new schema,inferred_od600sis nowod600s. Seepioreactor.structs.
Problems? Let me know here or at cam@pioreactor.com.
