New Pioreactor software release: 23.8.29
23.8.29
  • Pioreactor’s IPv4 and hostname is now displayed under System in the UI.
  • In configuration, renamed section dosing_automation to dosing_automation.config (only applies to new installs). It’s recommended for existing users to make this change, too.
  • new safety check that will stop automated dosing if vial liquid volume is above 18ml during dosing. This can be changed with max_volume_to_stop under [dosing_automation.config]
  • New configuration option waste_removal_multiplier to run the waste pump for a different multiplier (default 2), under [dosing_automation.config]
  • A warning will appear if the reference PD is measuring too much noise.
  • added another self-test test to confirm that an aturbid liquid in vial will produce a near 0 signal.
  • general improvements to self-test
  • New CLI command: pio clear-cache <cache> <key> to remove a key from a cache.
  • New CLI subcommand delete of pio run od_blank to remove the current experiment’s blank values. This is also exposed in the UI.
Changelog
Problems? Let me know here or at cam@pioreactor.com.
