this release fixes some bugs and provides some nice quality-of-life improvements!
Download the 25.9.18 release here
25.9.18
- Experiment profile editor: added a searchable capabilities browser. You can now search across available jobs, automations, actions, and options directly in the editor. This should make building and editing profiles faster and reduce syntax errors.
- Experiment Overview charts: no longer hide older data on long experiments. Instead, each series is downsampled on the client to a maximum of 720 points while preserving trends, regardless of experiment length. For very large clusters this may increase initial load time — narrowing the time range or hiding unused series can help if you notice slowness.
- Eye-spy optics: initial support is included. If detected, the OD reading job can use it via the existing interfaces. Nothing changes if you don’t have this hardware connected; more documentation will follow.
- Inventory export: from the Inventory page, you can export a worker’s
~/.pioreactordirectory as a zip. The Leader page also includes an export for the leader’s~/.pioreactor. This is useful for backups, support, or migration. Review the archive before sharing — it may contain configuration and credentials. - Pump scripting:
pio run pumps ...now accepts asleepstep to pause between actions. Example:pio run pumps --media 2 --sleep 1 --waste 1.5runs media for 2 mL, waits 1 s, then runs waste for 1.5 mL. In experiment profiles, you can repeat actions by suffixing keys with_, for example:jobs: pumps: actions: - type: start options: media: 2 sleep: 1 waste: 1.5 sleep_: 2 # repeat keys by adding underscores waste_: 0.5 - Advanced config for automations: the UI’s “Advanced” menu (temporary config overrides at start) is now available when launching automations, not just individual jobs. The options shown come from the
[<job_name>.config]section. - CLI: added leader-only experiment management commands —
pio experiments create <NAME>,pio experiments list, andpio experiments delete <NAME>.
- Restored live updates in real‑time charts in the UI (regression fixed).
- Corrected timestamps on exported dataset folders in the archive.
- Removed cases of duplicate log lines shown in the UI.
- MCP now correctly respects configured notification methods.
- Fixed model selection in the “Add a new Pioreactor worker” dialog in Inventory.
- For leader-only Pioreactors, fixed leaders not showing up in “Cluster clocks” (and likely other places)
- Turbidostat now enforces
duration = 0.25sfor its frequent checks. The UI already used this value; CLI runs will now match it for more consistent behavior.
