My Team and I have developed an alternative method to measure OD for our custom bioreactor, and it works with the Pioreactor control system through the i2C port.
The following are the shortcomings of the current stock Pioreactor OD system:
- It limits the diameter of the reactor chamber to allow measuring OD through the vial wall. Therefore, limiting the max volume of the pioreactor vessel.
- Small linear density range prevents high-density experiments. From the forum, the highest reported OD was 10 using the 45-degree scatter port. This is roughly a max of 5g/L for Ecoli, 2.5g/L for yeast, and 1.5g/L for spirulina.
- Any rotation in the vial’s position affects the OD readings
With our top-mounted probe design, the reactor volume limit is eliminated. Our sensor design methodology should be able to measure up to 200g/L, but we are in the process of validating this claim.
While this type of sensor already exists in industry, used models sell for 2500USD on eBay. They are also much bulkier than our design, making them unfit for stock Pioreactors. Offered by Mettler Toledo and Hamilton.
What we can offer:
If there is enough of a demand for this sensor, we are considering selling it. It will work with your current Pioreactor setups. Whether you want to use it with the 20mL vial or an 80L reactor, like we do.
What we are working on currently before bringing it to market:
- Probe will be made out of materials that can be autoclaved
- It will run an automated calibration script to convert the OD readings to biomass density in g/L. This is done by running calibrated dilution at a constant rate using a know density culture or calibration media and monitoring response to fit a linear relationship
- Further adapting the Kalman filter to the probe. Potentially removing the need to disable stirring, aeration, or LEDs (for PBRs) to take measurements
- We are in talks with suppliers to get user ready components for the complete probe
As you may have guessed, this has taken months of development and still requires some time. Our goal is to make this an affordable solution, essentially unlocking this otherwise priced out sensor. We do not yet have a final price for the sensor but it will be at a fraction of the currently available options.
Prior to proceeding in the development required to make this a user ready sensor, we need to gauge interest of the community. Please let me know if this is something you need.
Rafik
