Hey!
i’ve recently updated my cluster to 25.5.1 all the way from 24.10.1 (incrementally of course!) to take advantage of the OD600 calibration.
I was using the single vial protocol and measuring OD600 in a spectrophotometer (blanked with Lennox Broth (LB)) whenever prompted.
I’ve tried to run this calibration protocol a few times but it always seems to fail when I get to the end, where I’m asked to provide the OD of my media.
At first I assumed the best way to do this would be to blank my spectrophotometer with water, then measure the OD600 of LB (silly on my part, but I was not too sure what was being asked of me). I entered this value (~0.061), which resulted in the following:
Reading blank...
Reading is too high, trying again...
Why is the blank reading, 0.007061387502738081V, higher than everything else: [0.08381068184289237, 0.07215648153036494, 0.059990495649226594, 0.05049483620097249, 0.04423651213430242, 0.004209839326557134, 0.04119455321826533, 0.03336294465594032, 0.02946311569797438, 0.025674508836002266, 0.003870240992258537, 0.02760270349113583, 0.018774914875512375, 0.01613189389916026, 0.014452835004165283, 0.01590998482902551, 0.013372906049932187, 0.010782692998190914, 0.009790551716845626, 0.008856914993584195, 0.009094404629279238, 0.008290732050476476, 0.0070388222592080085, 0.006004920923917221, 0.005065548401484521, 0.005502664548161679, 0.005096614296223755, 0.0038720353411301565, 0.003920031518861105, 0.003423386589185564, 0.0037728271909961706, 0.004304656479406765, 0.005460199925158296, 0.005269595377488636]V?
Aborted!
So I repeated the entire process but this time when I was asked to provide the media OD, I kept the spectrophotometer blanked with LB and remeasured a sample of the same LB. = -0.006… basically zero, and definately lower than my other OD readings. Resulted in the same:
Why is the blank reading, 0.011804623729992577V, higher than everything else: [0.08572887852644015, 0.06913144112255011, 0.06055490458238791, 0.05343759899909553, 0.04884866447429399, 0.050517903532944566, 0.04250005741519082, 0.036254001121569984, 0.0331974130194098, 0.032081688791327445, 0.03146681145075177, 0.02784498121982694, 0.024038525857615747, 0.02209818950719277, 0.020272632813524847, 0.020731640539264115, 0.018113063005095027, 0.016773509531510813, 0.01545209817316242, 0.014024421185487917, 0.014980939113016057, 0.014124397378338177, 0.013436110830258531, 0.012556146641814607, 0.012526279286657657, 0.012476324362991481, 0.012708805337619988, 0.012860070246445247, 0.012968241865586785, 0.012190359031105035, 0.01266155225709167, 0.012146777486722512, 0.012030540999525217, 0.011592140435842562, 0.011631321204746416, 0.012906408419762342, 0.011877456060977131, 0.011984718381705617, 0.0115640098727537, 0.011383139760435099, 0.01305428554705593, 0.012505476041388491, 0.013109017645274711, 0.011919741775265492, 0.012259949400437106]V?
Aborted!
I know it could be a case of the first obviously failing because the blank value I provided was very high, and the second was negative. But writing zero here feels equally incorrect so I’m a bit stuck.
A few other bits:
- The curve for attempt 1 looked normal, though there were a few outliers.
- The second attempt was estimated to need 26 2mL dilutions, it actually required 36… So I assumed there may be an issue with the LEDs or something. I ran a self test and everything was normal. I also tried changing the REF value as Cameron outlined here: PD Blank signal too high - #3 by sharknaro, everything worked normally. The curve looked normal but with way more data points.
So, any advice on how to successfully calibrate the OD would be really appreciated!
