I am trying to save the OD calibration. However, I am keep getting this error log: ValueError: could not convert string to float: ‘auto’
sys.exit(pio())
File "/usr/local/lib/python3.11/dist-packages/click/core.py", line 1666, in invoke
rv = super().invoke(ctx)
File "/usr/local/lib/python3.11/dist-packages/click/decorators.py", line 33, in new_func
return f(get_current_context(), *args, **kwargs)
File "/usr/local/lib/python3.11/dist-packages/pioreactor/actions/od_calibration.py", line 729, in click_od_calibration
od_calibration(json_file)
File "/usr/local/lib/python3.11/dist-packages/pioreactor/actions/od_calibration.py", line 541, in od_calibration
data_blob = save_results(
File "/usr/local/lib/python3.11/dist-packages/pioreactor/actions/od_calibration.py", line 470, in save_results
ir_led_intensity=float(config["od_config"]["ir_led_intensity"]),
ValueError: could not convert string to float: 'auto'
I did not update for the most recent version so current version is 24.3.10.
Anyone had similar issue?
