I find the current method of OD calibration to be fairly time consuming, especially if calibrating multiple reactors.
What I want to do is have a set of standard 20ml vials with known OD readings. I just want to be able to say I’ve got 5 standards, go through put in the reference OD and then take the reading.
I’m not sure how well this is going to work using Impranil instead of cells, but it is probably better than not calibrating, and much simpler with no time dependence.
I’ve revised the od_calibration.py, but I don’t know where to put it. It is supposed to function just like the old one, but can be called with pio run od_calibration stdcal
Could you please advise how to replace the original od_calibration.py?
