Experienced some discrepancies while using post/pre delay OD setup:
Turning on the OD measurement:
- Some of the Pioreactors stop with
pre_delay_durationwhile others continue to stir without stopping. However, turn-off and turn-on of OD fixes the issue and all the workers stop to obey thepre_delay_duration.
Turning off an on going OD measurement:
- The stirring gets more vigorous.
- The OD readings jump high and then level off to the initial OD values (picture attached below to illustrate).
- The temperature increases slightly, causing the thermostat fluctuations (picture attached bellow to illustrate).
Did anyone else experienced similar issues?
Pioreactor config.ini setup
[stirring.config]
target_rpm=500
initial_duty_cycle=50
pwm_hz=400
use_rpm=1
duration_between_updates_seconds=23
post_delay_duration=0.25
pre_delay_duration=1.30
# if turning enable_dodging_od on, we recommend decreasing samples_per_second to at most 0.10
enable_dodging_od=True
[od_reading.config]
# how many optical density measurements should be published per second? Recommended maximum is 1.
samples_per_second=0.05
Pioreactor software information
Software version: 25.3.5
Pioreactor models: v1.1
