Pioreactor hardware is not powering on
Hello,
I was running a chemostat, and when I returned the next morning, I noticed that the LED lights on the Pioreactor were not blinking. The LAN port also showed no activity. I couldnt access it through UI or via SSH: The power outlet was the same one used by the other Pioreactors, which were functioning normally. Upon checking the vial, I noticed some water droplets at the bottom. Since then, I have been unable to power on the Pioreactor. Do you have any suggestions?
