I tried cd /var/www/pioreactorui/ && sudo pip install -r requirements.txt anyways and I think there was one thing that it ended up installing. That actually ended up fixing it and now it is showing up on the web page. Unfortunately I tried the cat command and now I don’t know how to look at everything before the cat output.
Thanks for the fix!
Edit:
I did notice these two error messages pop up in the event log.
| 17:20:58 | pioreactor1 | get job contrib | Yaml error in /var/www/pioreactorui/contrib/jobs/08_self_test.yaml: Object missing required field type - at $.published_settings[0]
| 17:20:58 | pioreactor1 | get job contrib | Yaml error in /var/www/pioreactorui/contrib/jobs/07_od_blank.yaml: Object missing required field type - at $.published_settings[0]
