Hi,
I am trying to calibrate the three pumps on my Pioreactor. I followed the instructions in the documentation and ran “pio run pump_calibration”. I ran into the same error shown below on both my Pioreactors. I need help resolving the same.
File “/usr/local/bin/pio”, line 8, in
sys.exit(pio())
File “/usr/local/lib/python3.11/dist-packages/click/core.py”, line 1666, in invoke
rv = super().invoke(ctx)
File “/usr/local/lib/python3.11/dist-packages/click/decorators.py”, line 33, in new_func
return f(get_current_context(), *args, **kwargs)
File “/usr/local/lib/python3.11/dist-packages/pioreactor/actions/pump_calibration.py”, line 649, in click_pump_calibration
pump_calibration(min_duration, max_duration, json_file)
File “/usr/local/lib/python3.11/dist-packages/pioreactor/actions/pump_calibration.py”, line 444, in pump_calibration
logger = create_logger(“pump_calibration”, unit=unit, experiment=experiment)
File “/usr/local/lib/python3.11/dist-packages/pioreactor/logging.py”, line 170, in create_logger
file_handler = handlers.WatchedFileHandler(config[“logging”][“log_file”])
File “/usr/lib/python3.11/logging/handlers.py”, line 479, in init
logging.FileHandler.init(self, filename, mode=mode,
File “/usr/lib/python3.11/logging/init.py”, line 1181, in init
StreamHandler.init(self, self._open())
File “/usr/lib/python3.11/logging/init.py”, line 1213, in _open
return open_func(self.baseFilename, self.mode,
PermissionError: [Errno 13] Permission denied: ‘/var/log/pioreactor.log’
