Hi there!
The relay plugin works fine on my leader, but when I try running it on a worker it just fails silently?
Hi there!
Hi @gendor,
Hm, are you using the latest version? I think I broke plugin installation on workers in it…
Otherwise, try SSHing into your worker and checking if it’s installed:
pio plugins list
If you have access to the internet, you can still install plugins with:
sudo pip3 install pioreactor-relay-plugin
Yes, I’m on the latest version. pio plugins appears to be missing on the worker:
pioreactor@worker1:~ $ pio plugins list
Usage: pio [OPTIONS] COMMAND [ARGS]...
Try 'pio --help' for help.
Error: No such command 'plugins'.
Manually installing the plugin using pip3 worked! ![]()
