Since from the last 2-3 software updates, when I remove the Pioreactors form the cluster and try to add them again after flashing the SD cards. I am constantly getting denial because the ssh key of the removed Pioreactor remains saved in known_hosts file of the leader.
If I go the command line interface and remove the ssh key of the respective Pioreactor, then I can add the pioreactor after that.
Hence, I was wondering:
- Did anyone experience similar issue?
- Could this be a bug in the recent updates or more of a personal issue?
The respective error log that gets generated in this case should be similar to this:
e[32m2024-05-26T16:08:55+0200 INFO [add_pioreactor] Adding new pioreactor P02 to cluster.e[0m e[31m2024-05-26T16:11:41+0200 ERROR [add_pioreactor] + set -e + export LC_ALL=C + LC_ALL=C + SSHPASS=raspberry + PIO_VERSION=1.0 + PIO_MODEL=pioreactor_20ml + HOSTNAME=P02 + HOSTNAME_local=P02.local + USERNAME=pioreactor ++ hostname + LEADER_HOSTNAME=L01 + ssh-keygen -R P02.local + ssh-keygen -R P02 ++ getent hosts P02.local ++ cut '-d ’ -f1 + ssh-keygen -R 10.42.0.217 + N=120 + counter=0 + sshpass -p raspberry ssh pioreactor@P02.local ‘test -d /home/pioreactor/.pioreactor && echo ‘'‘exists’'’’
EDIT:
I am using leader_only image on the leader and 24.5.22 software version in all the Pioreactors
Hi @sharknaro,
We haven’t seen this issue before. In the script to add a new worker, we execute:
# remove from known_hosts if already present
ssh-keygen -R "$HOSTNAME_local" >/dev/null 2>&1
ssh-keygen -R "$HOSTNAME" >/dev/null 2>&1
ssh-keygen -R "$(getent hosts "$HOSTNAME_local" | cut -d' ' -f1)" >/dev/null 2>&1
which should clear the key from known_hosts for the hostname, hostname.local, and ip. What command do you have execute before it works? Maybe we can add that command to our script.
Hi @CamDavidsonPilon,
The script you provided should work fine as it is what I have executed as well, so the steps I followed was:
Inside the leader, remove pio_worker.local in the known_hosts file
ssh-keygen -f "/home/pioreactor/.ssh/known_hosts" -R "P081.local"
Clear the cache
sudo systemctl restart ssh
Perhaps the way I removed the workers were not sufficient. I just clicked remove to the respective worker in the_inventory_. I do not know if I also had to run additional steps in the command line or config.ini
Should be fine! That’s the way we expect you to do it.
Hm, I wonder if we should look into clearing the cache too, or specify the file…
We can certainly harden this up for you.
