Did anyone else experienced an issue with the OD dodging with reduced stirring after the final update (25.6.25)?
[stirring.config]
initial_duty_cycle=50
pwm_hz=300
use_rpm=1
duration_between_updates_seconds=23
post_delay_duration=1.0
pre_delay_duration=2.0
# if turning enable_dodging_od on, we recommend decreasing samples_per_second to at most 0.10
enable_dodging_od=True
target_rpm_during_od_reading = 0
target_rpm_outside_od_reading = 800
initial_target_rpm = 800
The config stirring setup above results with the error log as stated below:
