I am trying to set up a dosing automation profile that starts when the culture reachs a certain OD. Here is the profile I am using that ChatGPT generated:
experiment_profile_name: custom_chemostat_pr1_with_batch_mode
metadata:
author: Your Name
description: Custom chemostat operation for Pioreactor pr1 with initial batch mode growth for the first 5 hours, followed by chemostat operation maintaining constant stirring and temperature, with a dilution rate of 0.3 h⁻¹ (0.63 mL every 9 minutes) and growth rate estimation.
pioreactors:
pr1:
jobs:
stirring:
actions:
- type: start
hours_elapsed: 0.0
options:
target_rpm: 650.0
temperature_control:
actions:
- type: start
hours_elapsed: 0.0
options:
automation_name: thermostat
target_temperature: 30.0
od_reading:
actions:
- type: start
hours_elapsed: 0.0
growth_rate_calculating:
actions:
- type: start
hours_elapsed: 0.0
dosing_control:
actions:
- type: start
hours_elapsed: 0.0
if: pr1:od_reading:normalized_od >= 30
options:
automation_name: chemostat
volume: 0.63
duration: 9 # In minutes, which translates to 0.1 mL every 2.1 minutes
I think the line in particular that is giving me issues is this one
Hi @kradical,
This is possible, but you currently have to use the repeat action to enable it. Maybe in a future release we’ll create a syntax to make these “start when X” easier. Until then, here’s your solution. Let’s discuss it:
In profile, this looks like:
metadata:
author: Your Name
pioreactors:
pr1:
jobs:
stirring:
actions:
- type: start
hours_elapsed: 0.0
options:
target_rpm: 650.0
actions:
- type: start
hours_elapsed: 0.0
options:
od_reading:
actions:
- type: start
hours_elapsed: 0.0
actions:
- type: start
hours_elapsed: 0.0
dosing_control:
actions:
- type: repeat
hours_elapsed: 0.08 # start after 5m
repeat_every_hours: 0.08 # check every ~5m
while: pr1:growth_rate_calculating:od_filtered.od_filtered <= 30
actions:
- type: start
hours_elapsed: 0.079
if: pr1:growth_rate_calculating:od_filtered.od_filtered > 30
options:
volume: 0.63
Thank you,
I have run into another issue so I copied and pasted this profile to work for the workers in my clusters and it runs the profile fine in the leaders but it only starts the temperature automation in the workers.
pioreactors:
pr2:
jobs:
stirring:
actions:
- type: start
hours_elapsed: 0.0
options:
target_rpm: 650.0
actions:
- type: start
hours_elapsed: 0.0
options:
od_reading:
actions:
- type: start
hours_elapsed: 0.0
actions:
- type: start
hours_elapsed: 0.0
dosing_control:
actions:
- type: repeat
actions:
- type: start
options:
volume: 0.63
pr4:
jobs:
stirring:
actions:
- type: start
hours_elapsed: 0.0
options:
target_rpm: 650.0
actions:
- type: start
hours_elapsed: 0.0
options:
od_reading:
actions:
- type: start
hours_elapsed: 0.0
actions:
- type: start
hours_elapsed: 0.0
dosing_control:
actions:
- type: repeat
actions:
- type: start
options:
volume: 0.84
Hm, I’m not sure I understand. Can you explain the issue to me again?
When I tried running this automation it would start fine in the host but for the workers it would only show the temperature automation as having started.
