Hey,
Maybe this is a stupid question, but after running the stirrer calibration I do not get any confirmation or message whether it ran correctly or not. Should there be one? The stirring does start after starting the calibration
Hey,
Hi @Stkral
Looking at the code, we don’t report anything, but we should!
You can check it saved something by running pio view-cache stirring_calibration on the Pioreactor it ran on.
If it fails does it result in an error message?
Yes, an error or warning message. Are you experiencing something unexpected?
Hey Cameron,
Not really, but I am using different (crossbar) stirrers, of which @sharknaro mentioned they failed the stirring calibration. But for me it seems to work ![]()
Hi @Stkral,
It is true that I was experiencing issues with this before, however from software version 26.6.x and above, I did not get any problems. In addition, if the calibration failes you get informed with a “yellow warning” in the logs. Hence, if you did not get anything this should mean that the calibration went fine :))
