I am trying to update from 23.12.11 to 24.2.26 using the “Updates” tab on the Pio’s web interface. When I attempt this I get the following errors:
Error occurred: RAN: /usr/bin/ssh pioreactor1.local 'pio update app' STDOUT: STDERR: e[36m2024-02-29T16:15:11-0500 DEBUG [update-app] sudo pip3 install "pioreactor @ https://github.com/Pioreactor/pioreactor/releases/download/24.1.9/pioreactor-24.1.9-py3-none-any.whl"e[0m e[36m2024-02-29T16:15:11-0500 DEBUG [update-app] sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper sudo: a password is required e[0m e[31m2024-02-29T16:15:11-0500 ERROR [update-app] Update failed. See logs.e[0m Aborted! . See logs for more.
and
+ set -e + export LC_ALL=C + LC_ALL=C + SRC_TAR=/tmp/pioreactorui.tar.gz ++ mktemp -d -t pioreactorui_XXXX + TEMP_DIR=/tmp/pioreactorui_Ls19 + UI_FOLDER=/var/www/pioreactorui + trap finish EXIT + tar -xzf /tmp/pioreactorui.tar.gz -C /tmp/pioreactorui_Ls19 ++ find /tmp/pioreactorui_Ls19 -mindepth 1 -maxdepth 1 -type d + WORK_DIR=/tmp/pioreactorui_Ls19/pioreactorui-24.2.25 + echo /tmp/pioreactorui_Ls19/pioreactorui-24.2.25 + [[ -z /tmp/pioreactorui_Ls19/pioreactorui-24.2.25 ]] + rsync -ap --ignore-existing /var/www/pioreactorui/contrib/ /tmp/pioreactorui_Ls19/pioreactorui-24.2.25/contrib/ + cp -p /var/www/pioreactorui/.env /tmp/pioreactorui_Ls19/pioreactorui-24.2.25 + rm -rf /var/www/pioreactorui + mkdir /var/www/pioreactorui + cp -rp /tmp/pioreactorui_Ls19/pioreactorui-24.2.25/. /var/www/pioreactorui + chgrp -R www-data /var/www/pioreactorui + finish + rm -rf /tmp/pioreactorui_Ls19 + sudo systemctl restart lighttpd.service sudo: a terminal is required to read the password; either use the -S option to read from standard input or configure an askpass helper sudo: a password is required
I’m guessing there needs to be a password (presumably the SSh password I set when installing to the MicroSD), but I cannot figure out how to add this. Any help is appreciated.
