Hi Pioreactor,
When running OD dodging the value of target_rpm_outside_od_reading cannot be modified through Settings. One solution is to stop the run, modify the config, and re-start the Pio. In Settings there is a section to modify the Target RPM, however, this gets overwritten by the target_rpm_outside_od_reading after the OD measurements.
Can there be a section in Settings to update the target_rpm_outside_od_reading or can Target RPM gets assigned differently at the system level so regardless of OD dodging being active, it updates the currenlty set target RPM?
